This may be useful to PixInsight users, especially with slightly older computers, speed up your PixInsight installation but up to 30% with extra swap folders, it really does help, all information and instructions here in my latest video..hope it helps..👍🏻 https://youtu.be/ytp_bJbu_1A?si=HWBhmaLJNXw-JMR4 |
I did this modification and yes, it worked, but just den opposite way - the additional folders slowed down the entire process. Here the two reports to compare…
Frist AFTER the added swap folders:
******************************************************************************* The Official PixInsight Benchmark version 1.0 Copyright (C) 2014-2021 Pleiades Astrophoto. All Rights Reserved. *******************************************************************************
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. M9W31LQ627R7IWEF927890672Y022HB0
CPU Identification CPU vendor …………. GenuineIntel CPU model ………….. Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
System Information Platform …………… Windows Operating system ……. Microsoft Windows 11 Pro Core version ……….. PixInsight Core 1.8.9-3 (x64) Logical processors ….. 12 Total memory size …… 31.739 GiB
Execution Times Total time …………. 01:43.06 CPU time …………… 00:39.71 Swap time ………….. 01:03.32 Swap transfer rate ….. 261.773 MiB/s
Performance Indices Total performance …… 4564 CPU performance …….. 9533 Swap performance ……. 1450
And here BEFORE I added the swap folders as per your suggestion:
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. TZNYX3H6Z17GHC4X6GWW4448GU2T3BMD
Execution Times Total time …………. 00:55.79 CPU time …………… 00:40.00 Swap time ………….. 00:15.76 Swap transfer rate ….. 1051.615 MiB/s
Performance Indices Total performance …… 8432 CPU performance …….. 9463 Swap performance ……. 5824
I asked my self why did this happen? Well - easy explanation - my additional drives D and E are "normal" hard drives and not SSD drives, so those slow the process down, right?
I deleted the additional swap files on E (the slower drive) and ran the benchmark test again - now it is faster, not much, but yes, faster
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. 89F1Q87KIVGPK7YT3104B7MPH3062563
Execution Times Total time …………. 00:53.49 CPU time …………… 00:44.64 Swap time ………….. 00:08.81 Swap transfer rate ….. 1881.669 MiB/s
Performance Indices Total performance …… 8794 CPU performance …….. 8480 Swap performance ……. 10422
Georg
Georg N. Nyman: I did this modification and yes, it works fine! Here the two reports to compare...
Frist before the added swap folders:
Benchmark version ...... 1.00.08 Input checksum ......... 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number .......... M9W31LQ627R7IWEF927890672Y022HB0
CPU Identification CPU vendor ............. GenuineIntel CPU model .............. Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
System Information Platform ............... Windows Operating system ....... Microsoft Windows 11 Pro Core version ........... PixInsight Core 1.8.9-3 (x64) Logical processors ..... 12 Total memory size ...... 31.739 GiB
Execution Times Total time ............. 01:43.06 CPU time ............... 00:39.71 Swap time .............. 01:03.32 Swap transfer rate ..... 261.773 MiB/s
Performance Indices Total performance ...... 4564 CPU performance ........ 9533 Swap performance ....... 1450
And here after I added the swap folders as per your suggestion:
Benchmark version ...... 1.00.08 Input checksum ......... 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number .......... TZNYX3H6Z17GHC4X6GWW4448GU2T3BMD
Execution Times Total time ............. 00:55.79 CPU time ............... 00:40.00 Swap time .............. 00:15.76 Swap transfer rate ..... 1051.615 MiB/s
Performance Indices Total performance ...... 8432 CPU performance ........ 9463 Swap performance ....... 5824
******************************************************************************* Wow, That’s a great increase, glad it worked for you…👍🏻
AstroShed:
******************************************************************************* Wow, That’s a great increase, glad it worked for you…👍🏻 I was making a mistake, which I corrected right away but you responded just a minute before - sorry for that mistake - now the values and data are correct! Apologize.... CS Georg
Sadly I don't believe this will speed up WBPP, only the processing of individual images and especially undo/redo. But thankfully, now we have FastBatchProcessing and FastIntegration.
Die Launische Diva: Sadly I don't believe this will speed up WBPP, only the processing of individual images and especially undo/redo. But thankfully, now we have FastBatchProcessing and FastIntegration. Yes as I stated in the video, it’s only for Processes, and does not help with scripts….👍🏻
Is posting videos to farm views really an appropriate use of Astrobin forums?
Dark Matters Astrophotography: Is posting videos to farm views really an appropriate use of Astrobin forums? If it is against any rules or people are really not happy then I will gladly take it down. Also I am not posting to farm views, I am posting as I thought it was maybe good information and possibly helpful….but like I say I am happy to remove if people are really not happy….👍🏻
Dark Matters Astrophotography: Is posting videos to farm views really an appropriate use of Astrobin forums? You are in here posting your images and promoting your business, is that not the same thing, and I don’t and won’t make any money out of it like you do…so maybe people in glass houses and all that…
AstroShed:
Dark Matters Astrophotography: Is posting videos to farm views really an appropriate use of Astrobin forums? You are in here posting your images and promoting your business, is that not the same thing, and I don’t and won’t make any money out of it like you do…so maybe people in glass houses and all that… We pay for advertising here, and our gallery is a paid for service like everyone else has.
AstroShed:
We pay for advertising here, and our gallery is a paid for service like everyone else has. And I pay for my service here too….
Right on. If you want to promote your channel Sal offers good rates on advertising. We leverage that and Sponsor the site as well. https://welcome.astrobin.com/sponsors-and-partners/dark-matters-astrophotography |
AstroShed:
We pay for advertising here, and our gallery is a paid for service like everyone else has. If you think it is so wrong, why are you lurking around on this thread, nobody made you come here, but maybe others will find it useful…just a thought…🤷🏼♂️
Dark Matters Astrophotography: Right on. If you want to promote your channel Sal offers good rates on advertising. We leverage that and Sponsor the site as well.
https://welcome.astrobin.com/sponsors-and-partners/dark-matters-astrophotography Good for you well done, and I bet you make a good load of money from the advertising, which is fine, I am not here to make any money at all, I don’t and won’t even monetise my Chanel… have a nice day…
Using an NVME SSD disk makes a difference! This without changing anything.
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. N7KS143LB7K7WOB0491BW74JJ2JER4V2
CPU Identification CPU vendor …………. AuthenticAMD CPU model ………….. AMD Ryzen 7 3700X 8-Core Processor
System Information Platform …………… Windows Operating system ……. Microsoft Windows 10 Pro Core version ……….. PixInsight Core 1.8.9-2 (x64) Logical processors ….. 16 Total memory size …… 15.952 GiB
Execution Times Total time …………. 00:36.04 CPU time …………… 00:24.79 Swap time ………….. 00:11.19 Swap transfer rate ….. 1480.772 MiB/s
Performance Indices Total performance …… 13052 CPU performance …….. 15266 Swap performance ……. 8201
Thanks for the tip. It increased my performance significantly.
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. B0LR1TX91BV1ES5F3EGWY6W89Y1C2H5J
CPU Identification CPU vendor …………. GenuineIntel CPU model ………….. 12th Gen Intel(R) Core(TM) i9-12900K
System Information Platform …………… Windows Operating system ……. Microsoft Windows 11 Pro Core version ……….. PixInsight Core 1.8.9-3 (x64) Logical processors ….. 24 Total memory size …… 63.696 GiB
Execution Times Total time …………. 00:26.57 CPU time …………… 00:16.57 Swap time ………….. 00:09.92 Swap transfer rate ….. 1670.016 MiB/s
Performance Indices Total performance …… 17705 CPU performance …….. 22847 Swap performance ……. 9249
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. WDM68006SLK0K57KB87UJ7F22ZZ8Q86L
Execution Times Total time …………. 00:16.97 CPU time …………… 00:13.98 Swap time ………….. 00:02.94 Swap transfer rate ….. 5636.195 MiB/s
Performance Indices Total performance …… 27718 CPU performance …….. 27066 Swap performance ……. 31216
Adriano: Using an NVME SSD disk makes a difference! This without changing anything.
Benchmark version ...... 1.00.08 Input checksum ......... 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number .......... N7KS143LB7K7WOB0491BW74JJ2JER4V2
CPU Identification CPU vendor ............. AuthenticAMD CPU model .............. AMD Ryzen 7 3700X 8-Core Processor
System Information Platform ............... Windows Operating system ....... Microsoft Windows 10 Pro Core version ........... PixInsight Core 1.8.9-2 (x64) Logical processors ..... 16 Total memory size ...... 15.952 GiB
Execution Times Total time ............. 00:36.04 CPU time ............... 00:24.79 Swap time .............. 00:11.19 Swap transfer rate ..... 1480.772 MiB/s
Performance Indices Total performance ...... 13052 CPU performance ........ 15266 Swap performance ....... 8201 Wow, those are very fast, my processor is faster I have 64gb RAM and my main drive is an NVME and my figures are no where near yours…😮👍🏻
AstroShed:
Performance Indices Total performance ...... 13052 CPU performance ........ 15266 Swap performance ....... 8201 Wow, those are very fast, my processor is faster I have 64gb RAM and my main drive is an NVME and my figures are no where near yours…😮👍🏻 From what I understand in the video, your hard drive is a SATA SSD.
More results.
Before:
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. TWUG53P8888264Y2DQF0YCMKO2R1555K
CPU Identification CPU vendor …………. AuthenticAMD CPU model ………….. AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
System Information Platform …………… Windows Operating system ……. Microsoft Windows 11 Pro Core version ……….. PixInsight Core 1.8.9-3 (x64) Logical processors ….. 16 Total memory size …… 27.717 GiB
Execution Times Total time …………. 00:46.08 CPU time …………… 00:39.62 Swap time ………….. 00:06.42 Swap transfer rate ….. 2583.342 MiB/s
Performance Indices Total performance …… 10208 CPU performance …….. 9553 Swap performance ……. 14308
After:
Benchmark version …… 1.00.08 Input checksum ……… 2cd72b67e12fff2812ef5b5da054ab2a70a25e23 Serial number ………. 139XI05FU7HE521K4NDQ1FFZB1LL96XZ
Execution Times Total time …………. 00:45.55 CPU time …………… 00:40.11 Swap time ………….. 00:05.38 Swap transfer rate ….. 3078.112 MiB/s
Performance Indices Total performance …… 10327 CPU performance …….. 9436 Swap performance ……. 17048
Adriano:
AstroShed:
Performance Indices Total performance ...... 13052 CPU performance ........ 15266 Swap performance ....... 8201 Wow, those are very fast, my processor is faster I have 64gb RAM and my main drive is an NVME and my figures are no where near yours…😮👍🏻 From what I understand in the video, your hard drive is a SATA SSD. No, my main C drive is NVME my second D drive is an M.2 Sata, and my third driver is jut a bog standard 2.5” SSD sata drive…👍🏻
AstroShed:
Adriano:
AstroShed:
Performance Indices Total performance ...... 13052 CPU performance ........ 15266 Swap performance ....... 8201 Wow, those are very fast, my processor is faster I have 64gb RAM and my main drive is an NVME and my figures are no where near yours…😮👍🏻 From what I understand in the video, your hard drive is a SATA SSD. No, my main C drive is NVME my second D drive is an M.2 Sata, and my third driver is jut a bog standard 2.5” SSD sata drive…👍🏻 SATA and M2 disks are hampering system performance.
Adriano:
AstroShed:
Adriano:
AstroShed:
Performance Indices Total performance ...... 13052 CPU performance ........ 15266 Swap performance ....... 8201 Wow, those are very fast, my processor is faster I have 64gb RAM and my main drive is an NVME and my figures are no where near yours…😮👍🏻 From what I understand in the video, your hard drive is a SATA SSD. No, my main C drive is NVME my second D drive is an M.2 Sata, and my third driver is jut a bog standard 2.5” SSD sata drive…👍🏻 SATA and M2 disks are hampering system performance. I may try the full 12 swap files on my one main NVME drive, and see if that helps rather than use 4 swap files on all 3 drives I have…worth a try
Interesting. I tried this on my MacBook Pro M2 with a 2TB SSD and it made essentially zero difference.
It would be nice if, when reporting results, participants would provide information about their hardware.
John Hayes: Interesting. I tried this on my MacBook Pro M2 with a 2TB SSD and it made essentially zero difference.
John you can extrapolate that information by the OS and chipset. Or were you talking about something more specific?
Dark Matters Astrophotography: Is posting videos to farm views really an appropriate use of Astrobin forums? Just curious, but how would you have done it? it seems like you’re making a ridiculous assumption to claim that @AstroShed is trying to “farm views”. Should we infer that it would be better to download the transcript from the video and post it as a pdf? Anyway, thanks for the info @AstroShed i had originally thought that it needed different folders on different drives. Loading in the same drive multiple times on two of my loaded drives brought me down to 2.50” of swap speed. Very nice!
