My script to allow you to remove artifacts and blemishes within PI in a much more robust fashion than what is normally accomplished with CloneStamp. All algorithmically based on the actual structures surrounding the blemish, no AI in sight. Video details how it all works, but in short it looks at the 6 surrounding tangent circles to the defined area you want the artifact or blemish removed. Determines the 3 that most closely match the center one and pixel by pixel determine the median of those 3 areas and build up the center area. Link to the video: https://youtu.be/iXYUeWEIDpgMy site for all my scripts: https://www.setiastro.com/pjsr-scriptsYou can update PixInsight via Resources -> Manage Repositories and add the following URL: https://raw.githubusercontent.com/setiastro/pixinsight-updates/main/Build 1605 or higher is needed to use the Repository. Comments and Suggestions highly appreciated!   |
Awesome! Can't wait to check this out.
Genius! I 'll check it for sure. Thanks for posting!
that sounds pretty good!
clone stamp does not always give good results, good option for testing.
greetings
Site to get the repository link and standalone zip: https://www.setiastro.com/pjsr-scripts Hi Frank "Seti"! I get the following error in PI. Tx! Ciao  |
Great !!! Will try it very soon !
Adriano:
 You need build 1605 or higher to use the repository. What build to you have?
That isnt the link to the repository. That is my website page wherw you can find the link. This is the repository https://raw.githubusercontent.com/setiastro/pixinsight-updates/main/ |
Franklin Marek: You need build 1605 or higher to use the repository. What build to you have? |
A valuable addition – thanks for developing and sharing it! Two comments: - It would be nice to have zoom controls instead of always looking at the picture in 100% scale. - When I drag the scroll bar to get to the desired point (instead of just clicking on/in it), I quickly get into a featureless white area which the image doesn’t actually have:  Thanks, Francesco
Franklin Marek: That isnt the link to the repository. That is my website page wherw you can find the link. This is the repository https://raw.githubusercontent.com/setiastro/pixinsight-updates/main/ Ahh - that's it! I have downloaded it now, thank you!
Franklin Marek:
Adriano:
Franklin Marek:
Adriano:
 You need build 1605 or higher to use the repository. What build to you have? I assume that build is the 1.8.9-3???
Francesco Meschia: A valuable addition – thanks for developing and sharing it! Two comments: - It would be nice to have zoom controls instead of always looking at the picture in 100% scale. - When I drag the scroll bar to get to the desired point (instead of just clicking on/in it), I quickly get into a featureless white area which the image doesn’t actually have:  Thanks, Francesco Zoom out with the mouse wheel  |
Dale Penkala:
Franklin Marek:
Adriano:
 You need build 1605 or higher to use the repository. What build to you have? I assume that build is the 1.8.9-3??? That isnt the build number. If they are getting signing errors they have an old build of PI
Adriano:
Franklin Marek:
Adriano:
 Looks like you have a lot that needs updating, there is a creator signature table if you scroll up in your update window. Get everything updated and it should be good to go
Dale Penkala:
Franklin Marek:
Adriano:
 You need build 1605 or higher to use the repository. What build to you have? I assume that build is the 1.8.9-3??? 1.8.9-2
Thank you very much for your new script, greetings from Chile
Thanks for that, I'll check it with pleasure. Usually, I had to use a similar feature within Affnity Photo.
Looks great - will try it later tonight.
Thank you for developing and posting this!!
Excellent tool. Works very well! Thanks!
Jim
Franklin Marek:
Adriano:
Franklin Marek:
Adriano:
 Looks like you have a lot that needs updating, there is a creator signature table if you scroll up in your update window. Get everything updated and it should be good to go Thanks a lot for the help. I managed to install it!
Franklin Marek: Comments and Suggestions highly appreciated! A verbatim Repository link in your post would help. EDIT: I'm getting a failure. Manually installed it and it works, repository link didn't work.
DavesView:
A verbatim Repository link in your post would help. I'm getting a failure. Done!!  |
