Goodbye CloneStamp, Hello Blemish Blaster! Content Aware Healing Tool Pleiades Astrophoto PixInsight · Franklin Marek · ... · 48 · 2642 · 20
seti_v2 19.05
·  47 likes
My script to allow you to remove artifacts and blemishes within PI in a much more robust fashion than what is normally accomplished with CloneStamp.  All algorithmically based on the actual structures surrounding the blemish, no AI in sight.
Video details how it all works, but in short it looks at the 6 surrounding tangent circles to the defined area you want the artifact or blemish removed.  Determines the 3 that most closely match the center one and pixel by pixel determine the median of those 3 areas and build up the center area.
Link to the video: https://youtu.be/iXYUeWEIDpg
My site for all my scripts: https://www.setiastro.com/pjsr-scripts
You can update PixInsight via Resources -> Manage Repositories and add the following URL: https://raw.githubusercontent.com/setiastro/pixinsight-updates/main/
Build 1605 or higher is needed to use the Repository.
Comments and Suggestions highly appreciated!
Overcast_Observatory 19.90
Awesome!  Can't wait to check this out.
Mau_Bard 4.06
Genius!
I 'll check it for sure. Thanks for posting!
juanmaplay3 0.00
that sounds pretty good!
clone stamp does not always give good results, good option for testing.
greetings
Mau_Bard 4.06
Site to get the repository link and standalone zip: https://www.setiastro.com/pjsr-scripts
Hi Frank "Seti"! I get the following error in PI.
Tx! Ciao
Shark13 0.00
Great !!!
Will try it very soon !
Adry 0.00
seti_v2 19.05
Adriano:
You need build 1605 or higher to use the repository.  What build to you have?
seti_v2 19.05
Tx! Ciao
That isnt the link to the repository.  That is my website page wherw you can find the link.  This is the repository https://raw.githubusercontent.com/setiastro/pixinsight-updates/main/
Mau_Bard 4.06
Franklin Marek:
frankz 4.07
A valuable addition – thanks for developing and sharing it!
Two comments:
- It would be nice to have zoom controls instead of always looking at the picture in 100% scale.
- When I drag the scroll bar to get to the desired point (instead of just clicking on/in it), I quickly get into a featureless white area which the image doesn’t actually have: Screenshot 2024-07-29 at 08.11.17.png
Thanks,
Francesco
Mau_Bard 4.06
Franklin Marek:
Ahh - that's it!
I have downloaded it now, thank you!
Adry 0.00
Franklin Marek:
Adriano:
DalePenkala 19.38
Franklin Marek:
Adriano:
I assume that build is the 1.8.9-3???
seti_v2 19.05
Francesco Meschia:
Two comments:
Thanks,
Francesco
Zoom out with the mouse wheel
seti_v2 19.05
Dale Penkala:
Franklin Marek:
Adriano:
That isnt the build number.  If they are getting signing errors they have an old build of PI
seti_v2 19.05
Adriano:
Franklin Marek:
Adriano:
Looks like you have a lot that needs updating, there is a creator signature table if you scroll up in your update window.  Get everything updated and it should be good to go
Adry 0.00
Dale Penkala:
Franklin Marek:
Adriano:
 1.8.9-2
polaco_cosmico 0.00
Thank you very much for your new script, greetings from Chile
Vroobel
Thanks for that, I'll check it with pleasure. Usually, I had to use a similar feature within Affnity Photo.
Bennich 5.02
Looks great - will try it later tonight.
Thank you for developing and posting this!!
Juno16 5.01
Excellent tool. Works very well! Thanks!
Jim
Adry 0.00
Franklin Marek:
Adriano:
Franklin Marek:
Adriano:
Thanks a lot for the help. I managed to install it!
DavesView 2.39
Franklin Marek:
A verbatim Repository link in your post would help.
EDIT: I'm getting a failure. Manually installed it and it works, repository link didn't work.
seti_v2 19.05
DavesView:
Franklin Marek:
A verbatim Repository link in your post would help. I'm getting a failure.
Done!!
