Hello from France / Bonjour à tous ! Introduce yourself! · argth · ... · 6 · 408 · 2
argth 1.51
Hi !
Really happy to be on astrobin, I am returning to astrophoto after a few years not having much time for it. I began astrophotogrpahy in 2006 mainly using telescopes from the Observatoire de Haute Provence in France, now I am focused on light gear so I do all my work using a star adventurer mini and a full spectrum Canon 60d.
My quest of correct lenses made me try a bunch of brands and models :
 - Sigma 70-210 Zen Apo F2.8 –> Rejected : no correct until f/8
 - Tamron SP 70-200 F/2.8 Di LD –> Rejected  : no correct wide open in the corner
 - Tair 3 300 mm F/4.5 –> Correct and used for wide fields
 - Rubinar 500mm F/5.6 –>  Correct and used to take pictures of galaxies using a the star adventurer mini
 - Canon 200mm L F/2.8 –> Correct at F/3.2, used for wide fields
 - SMC super takumar 200mm F/4 –> Correct lens at F/5.6
 - PENTACON 135mm F/2.8 –> Correct lens at F/3.2
I am currently located in a really light poluted area near Paris.
TamRich1874 6.68
Bonjour Argth! And welcome to the Astrobin family.
Papangue 0.00
Welcome to Astrobin.
I am also part of the Paris Region family and its beautiful nocturnal lights. Right now, it's a little better because the streetlights go out at 11 p.m.
I'm also a fan of CANON and the Star Adventurer for travel.
What are your favorite software tools?
Harold
argth 1.51
Hello Harold,
Really happy to discuss with you !
My processing workflow for some time now is :
- SIRIL for processing
- Then AstrodenoisePy to make some noise removal
- Separation of stars and other objects using StarNetV2
- Separate histogram processing for stars and deep sky objects
- Merge the two using Gimp.
How do you work ?
Papangue 0.00
How do you work ?
For full deep sky object processing I use PixInsight and sometimes AstroPixel Processor for pre-processing.
For Earth Moon and planets I use PIPP, Registax 6, AutoStakkert!3 and Winjupos.
And for final adjustments, RawTherapee or Adobe PhotoShop.
argth 1.51
Noted ! I have no experience for planetary, so good to have some feedbacks when I will.
For now my main pain point is to correct background ! I have struguled a lot with this subject. Maybe you or other persons from astrobin forum would have an idea on how to improve ?
Even if I use a white T shirt during day light to take some flats with signal in the middle of the histogram, my result after stacking and background removal in SIRIL is :
I had to spend a huge time trying to remove these strange marks... Any suggestion ?
For reference my master flat (calculated by SIRIL with 17 frames  1/3200s @800 iso as the lights, focus at infinity, same rotation of lens)
Kaoru_Requiem 0.00
Hi arght.
I'm living near Paris too but with a sky not so bad (Bortle 5) so i can't complain.
