Hello from dark Poland Introduce yourself! · Dariusz · ... · 7 · 221 · 2
venonn 1.81
·  6 likes
Hi everyone,
I am from Poland, specifically from the southeastern part of the country, near the Bieszczady Mountains, where the SQM is around 21.8. I also often take photos from a city where the SQM is 19.8. I started my astrophotography journey in 2023 with a simple DSLR and an old telescope that was not suitable for astrophotography. Only this year, I bought a proper astrophotography telescope along with a cooled camera and a mount.
I see a lot of beautiful pictures on this forum, and I hope that one day I can create such stunning images too.
Best regards
TiffsAndAstro 1.81
Dariusz:
Hi everyone,
Best regards
fortunately it's so dark I can't read your post and get jealous
look forward to seeing your images and then getting jealous
Leonardo-Ruiz 4.01
Well, from my 8-9 Bortle sky, with an SQM of 17.8, I can only feel envioussmile. In that dark sky, whatever you do will turn out well. It really isn't even necessary to process the images much, just add hours of integration and save everything you do. Maybe today you don't know how to do complex processing, but in a short time you will begin to master it. What equipment do you have?
venonn 1.81
Leonardo Ruiz:
Well, from my 8-9 Bortle sky, with an SQM of 17.8, I can only feel envious. In that dark sky, whatever you do will turn out well. It really isn't even necessary to process the images much, just add hours of integration and save everything you do. Maybe today you don't know how to do complex processing, but in a short time you will begin to master it. What equipment do you have?
Thank you! My current equipment is:
  • Mount: EQM 35 PRO
  • Telescope: Sharpstar 61EDPH III
  • Camera: Svbony SV605CC
  • Filter: SVBONY SV220
  • Guide camera: ZWO ASI 120 mini
  • Guide scope: Svbony SV165 40 mm
This year, I plan to upgrade to a better mount or do a Hyper Tune on my current one to reduce guiding error.***
Leonardo-Ruiz 4.01
Let's go in parts:
Your 360 mm focal telescope, together with your 3.76 µm camera, will require an RMS of 2"/pixel from the mount, which is very easy to achieve if you do a good setup. I don't see the need to spend money on increasing the precision of the guidance for this focal, if that is going to be your usual equipment. If you wanted to improve, I would improve the resolution. With this configuration that you have (360 mm/3.76µm) you have under samplig, that is your equipment is not capable of getting all the detail out. Which is not a problem, don't be alarmed, it can take impressive photographs and with a little deconvolution processing, like BlurXterminator, you can get very good detail.
However, if you increase the focal length or reduce the pixel size of the image camera, you will improve the resolution. I leave you a link so you can play and see the calculations: https://astronomy.tools/calculators/ccd_suitability
Later, I will send you a resolution comparison between a Red cat 51 (250 mm) and a Televue NP101 IS (540 mm) with the same 3.76um ASI2600MM camera.
With this tool you will be able to know what resolution you get, which also coincides with the maximum RMS that you should achieve in the guidance. For example, as a future improvement, I would invest in a telescope with a larger focal length, over 500 mm, which would give you optimal resolution and would only require an RMS of 1.47"/pixel. You can also change to a camera with a smaller pixel size , 2 to 3 µm.
My advice is that you learn to use your equipment, keep it for 1 or 2 years, know your mount well, Nina or Asi Air, learn to process with Pixinsigth and retouch with photoshop and when you master everything, you will know what you want, smaller or biger field, higher resolution, higher optical quality, you will see it.
As for the Svony Dual Band filter, just tell you that you will have a Ha and O3 signal, but not S2, so when you use Narrow band filter you will have to process it as HOO or add the image to the RGB (search on YouTube, there are thousands of turorials).
Start without a filter, since you have an OSC camera it will give you a color image, learn how to stack, how to make calibration images. I started 24 years ago with an OSC in Bortle 3 sky and I just stacked without calibration. Well 24 years ago I used chemical film, but that is another topic.
I repeat, my advice is not to spend money now, because in a short time you will want to change the quality of your optics, filters and camera. I think your telescope is the same as the Radian Raptor 61, which had chromatic aberration in the blue. I had a Radian and got rid of it, because the stars looked like planets. My 22-year-old Televue NP101is never fails. For affordable future investments, think about an autofocuser and purchasing software licenses, pixinsigth and Photoshop.
Good luck and you'll show us some photos.
Leonardo-Ruiz 4.01
I show you the difference in resolution. On the left, the Televue NP101is, with a 540 mm focal length with the ASI2600MM of 3.76 μm pixel size, which provides optimal resolution. On the right the Red Cat 51 with 250mm focal length and identical pixel size. Both are perfectly focused, it is not a difference in focus but in resolution, but as I mentioned, it is not something drastic either, you can make excellent images under sampling.
Leonardo-Ruiz 4.01
Another comparison with a smaller zoom shows that although there is a difference, the result is very good.
tomrgray
Greetings and welcome to Astrobin, Dariusz. You will find a welcoming an helpful community.  You have a very nice setup, and you certainly don't need to spend all your money on this hobby - I pride myself on developing and maintaining a fairly simple rig, and showing what can be achieved - our night sky should be available to all, and there are so many confounding issues, not least light pollution - money doesn't fix everything!
You are very lucky to have access to such dark skies, and I look forward to seeing your images. I hope not too dark, as Poland borders Ukraine and the shadow of your larger and aggressive cousin looms - as we remember D-Day and the eventual liberation of Western Europe we do well to remember this, and the clear warnings from our East European friends. Per ardua ad astra…
