My Solar Viewer Application Anything goes · Steven Fanutti · ... · 20 · 260 · 3
sfanutti 1.91
Hi everyone,
This is my Solar Viewer application. I wrote this application to check solar activity before visual observing or an astrophotography session. It displays solar images taken by NASA spacecraft. Images in this video are used according to NASA's Image and Media Use Policy for non-commercial use.
https://youtu.be/EvVXTXI15-g?feature=shared
That's a handy app. Are you going to make it available it some point or just post a daily video on YouTube?
sfanutti 1.91
This app will work on all major OS's that support the latest Java SE.
sfanutti 1.91
Do you have Java SE installed on your machine? I can post the source code here if you want to compile it or the packaged app and you can just run it. What OS are you using?
It would be great if you could post the packaged app. I am using windows 11.
macmade 3.01
Nice! I'm also currently working on a similar application but for macOS.
I'll post a link once it's complete. smile
sfanutti 1.91
Here it is. Make sure you download Java SE from Oracle. Once installed, double-click the file and it should work right away.
JSolarViewerApp_2.jar
sfanutti 1.91
Jean-David Gadina:
Sounds great! If you want the source code for the program, here it is. It may help with your project.
JSolarViewerApp_2.java
macmade 3.01
Steven Fanutti:
Thanks.
I'm using Swift since macOS doesn't come with Java installed.
I'm almost done anyway! : )
sfanutti 1.91
Jean-David Gadina:
Steven Fanutti:
Thanks.
Works on macOS on my 2017 iMac with Java SE installed. I use Java SE for visual program development and Standard C++ for my terminal applications. For macOS users, once downloaded, rename the file to JSolarViewerApp_2.jar . When opening the file, macOS will warn you that you are trying to run a program downloaded from the internet and will give you the option to open it or not.
I also use Kubuntu. For Kubuntu/Ubuntu users, to run the program, you need to install Java first if you don't have it. On Kubuntu/Ubuntu, I recommend installing the JDK using the Synaptic Package Manager. One done, open a terminal window in the file directory and type:
java -jar JSolarViewerApp_2.jar
The program should run no problem.
sfanutti 1.91
To all AstroBin users: You can copy and share this program around as much as you like. I am making it free for use and distribution to the astronomical community. I do kindly ask if sharing it around to mention that you got it from me. smile
macmade 3.01
Steven Fanutti:
This is what it looks like currently. : )
astroswell 1.51
Nice work! Though what's the point of the app if there's a site https://www.thesuntoday.org/sun/current-observations/
macmade 3.01
Maxim:
Mostly having fun when it's cloudy.
Steven Fanutti:
Thank you!
macmade 3.01
All right, for macOS users, my application is now available from my GitHub, as well as the source code:
https://github.com/macmade/SDO
The application itself can be downloaded directly from:
https://github.com/macmade/SDO/releases/latest/download/SDO.zip
Enjoy! : )
sfanutti 1.91
Jean-David Gadina:
Enjoy! : )
@Jean-David Gadina
I'm running macOS Ventura 13.6.9. It doesn't seem supported on my 2017 iMac. Any suggestions? Maybe rebuild it on my system from the source? My system can't upgrade beyond Ventura unfortunately. I have Xcode Version 15.2.
sfanutti 1.91
Maxim:
@Maxim I see your point, but that's also true regarding some smartphone apps. I developed the program because I wanted a simplified, dedicated astronomy app without searching through browser bookmarks using a full-featured browser for simple viewing. You will also notice that the program reads the mouse pointer position, a useful feature if you are involved in The Sun Grazer Project:
https://sungrazer.nrl.navy.mil/
I'm not involved in the project myself, but I might get involved if I had more time for this hobby.
Steven
macmade 3.01
Steven Fanutti:
I've been able to lower the deployment target to macOS 10.15 Catalina.
I'm finishing adding a few more stuff, and I'll publish a new release.
I'll post a message when I'm done. : )
macmade 3.01
Steven Fanutti:
OK, you can try with the latest version:
sfanutti 1.91
Jean-David Gadina:
Steven Fanutti:
@Jean-David Gadina The app works great! No problem on Ventura!
I posted a few more videos of some applications that I have written over the years. Some of the videos didn't capture as sharp as I would have liked, but you can see them clearly enough.
https://youtube.com/@stevenfanutti?feature=shared
This is one of my more sophisticated applications:
https://youtu.be/YLlS2GcE2j8?feature=shared
Thanks,
Steven
