Optimum Exposure Length GAS Astrophotography Interest Group · Tim Ellison · ... · 3 · 71 · 1
Tim.Ellison 0.00
Hi all.
Whilst randomly browsing images in AstroBin I happened upon this one - https://astrob.in/agsyir/0/.
I thought it might be worth sharing - following the discussion on Monday - as it gives an alternative take on the subject of exposure lengths. Not everybody will like the idea of the number of frames involved though, I'm sure!
All the best
Tim
MartinBaker@1848 0.00
Well, that lot will slow up the PC. Blooming lovely result and shows it’s total integration time that is needed.
Being sad I had to work the figures out.
Ha 3.3 Hrs
L 2.1 Hrs
RGB 0.5 Hr each
In rough numbers.
1.5 & 2 sec subs. No guiding needed.
Didn’t see where it was taken.
Tim.Ellison 0.00
And presumably the short exposures would mean that a quite (very?) rough and ready polar alignment would suffice. Although a decently solid mount and an ability to track the target reasonably well would still be important. Does it offer you anything to chew on Keith??
maxchess 2.61
This guy was using a "Nauris Mirrage 600 mm f 3,8 Dobson"  this scope is not capable of accurate tracking so he was forced to use very short exposures to avoid star elongation / trails. Interestingly he used a Pegasus rotator to avoid field rotation. The total integration time for this image was 8 hours and the quality is relatively poor for this amount of time. There are clear photoshop halos round the main image.
See this image
with the same camera using only 3 hours and in Bortle 8 skies.
Max
