Hello Folks! So what is your equipment? Astrophotographers at Starfront Observatories · tsk1979 · ... · 17 · 374 · 8
tsk1979 0.00
Its so empty in here! Thought I would start a conversation.
Whats your equipment?
I am using Vixen R200SS with ASI2600MM Duo and a backup guidescope uniguide 50mm
Mount HAE29C
Other equipment :
Pegasus power box advance
Wanderer astro mini rotator
Qhy slim filter wheel
Minisforum TH50 -> 11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz   3.19 GHz
Astrofritz 0.00
Using a RedCat 51 with a 6200mm camera with Chroma 5nm Sho, and Lrgb filters.   Cgx mount and an SvBony 60mm guide scope with asi290mm guide cam.  Using Cpwi and Nina for data acquisition
tjhcom 0.00
Esprit 100ed with an ASI2600mm. I am using Antlia pro filters and very happy with the performance, particularly with the narrowband. 36mm unmounted.
c7c8 0.00
Esprit 100ED with an ASI6200MC, no filters. I used to travel 1-2 hours for astrophotography and averaged maybe 4-5 hours of good exposure every 2-3 months, so I went the OSC route originally. I'm planning on getting a filter wheel + filters next year, along with a swap to a monochrome camera.
JGAstronomy 2.41
I'm running a William Optics FLT91 with a 2600mm and Antlia LRGB / 3nm SHO filters on an AM5. Couldn't be happier with how everything has been running - great guiding numbers and obviously super clean data. I've been installed since mid-August.
I also have a Pegasus Falcon V2 installed and power the mount, camera, EFW, EAF all with a PPBAV. I've got a Wanderer V4 flat panel which is actually slightly too small, but I use it mainly to cover the objective end of my scope and typically just do sky flats instead.
Scotty_Maxwell 0.90
I'm jealous, I reserved a pier the day Bray announced it on his channel but haven't had my equipment ready.  I ordered a Camera from Moravian and an MKS6000 control board for my Paramount and just got them in.  I have been "field testing" the package here at the house to stomp out any gremlins before I take it.  So far it's been set up for 3 weeks but I haven't had to go touch it for the last two.  I think it's ready!
The rig consist of:
Scope: Takahashi FSQ106EDX
Focuser: Moonlite Nitecrawler WR35
CAA: Moonlite Sidewinder
OAG: Moravian C3 OAG with  my QHY 5iii174M
EFW: Moravian Large 50mm X 50mm square 7 slot
Filters: Astronomik 50mm X 50mm 6nm SHO, Deep Sky LRGB
Camera: Moravian C3-61000 pro with Moravian Power supply
Flat panel & motor: Primalucelab GIOTTO150 and ALTO1 with small PLL losmandy clamp
Mount: Paramount MyT - for weights 3 X 20lb and 1 X 10 lb are available with Paramount power supply
PC: PLL Eagle 5 XTM
Mounting hardware: PLL 495mm losmandy dovetail plate, PLL Rings
Network: Netgear 5 port unmanaged switch
Power distribution: Digital Loggers Web pro power strip
Monitor camera: Wyze surveillance camera if there's a place for it
adamgardner 0.00
System 1
ZWO AM3
ZWO FF65
ZWO ASI2600MC Pro
Filter drawer with UV/IR Cut, Antlia dual-band Ha/Oiii, Antlia dual-band Sii/Hb, and I think I sent some Optolong dual-band but I don't recall which one)
WO Uniguide 32
ZWO ASI120MM mini
PPADVGen2
System 2
ZWO AM3
Askar FRA400
ASI2600MM Pro
ZWO 7-pos 2" EFW
Antlia LRGB, Baader 6.5 nm SHO
WO Uniguide 32
ZWO ASI120MM mini
PPADVGen2
I've also got a Skydaddy flat panel down there for this one but I was having problems getting it to stay connected and recognized, so I had them take it off rather than waste any more precious dark sky time.  I've got cheating to do…
Zachary2112 0.00
I'm running:
OTA- Askar 103APO with 0.8x reducer
Mount- ZWO AM5
Camera- ASI533MC Pro
Autofocuser- ZWO EAF
Guide Scope- SVBony 165
Guide Camera- ZWO ASI120MM mini
Filters- L-eXtreme 2' and a ZWO uv/ir cut filter
Scotty_Maxwell 0.90
I'm glad Bray posted his video on how to measure your rig yesterday.  Somehow I missed before that the radius measurement was with the Flat/Cover full extended.  My 22" radius rig suddently went to 27" with my Alto1Giotto150mm fully extended (thats mounted on the bottom too).  Now I just have to decide if the next three years flats are worth $3,600 to have flat generator flats vs. sky flats….
ronht 0.90
RedCat 61
ZWO ASI2600MM Pro
ZWO ASIair Plus
ZWO AM5 mount
ZWO EFW w/full Chroma filter set
ZWO EAF
William Optics 32/120 guide scope w/ ZWO ASI220 mini guide cam
dg303pilot 0.00
William Optics FLT 91
ZWO AM5
Player One Poseidon Mono
Player One Filter Wheel w/ Chroma 5nm SHO & LRGB
William Optics Uniguide 50mm
ZWO ASI174 Mini
ZWO EAF
Pegasus Ultimate v3 Powerbox
Pegasus Falcon 2 Rotator
Wanderer Flat Panel Screen
JGAstronomy 2.41
@Jim Blubaugh good to see another FLT91 at Starfront! Are you using the 68iii flattener or the 0.8x reducer with yours?
dg303pilot 0.00
Jack Groves:
Hi Jack -  I'm running the .8 reduceer on mine. Have had this one for about 2 years now and loving it.  -Jim
david.quattlebaum 0.90
Astro-Physics 130 Starfire GTX
AM5N Mount
ZWO 2600 MC Pro
Eagle XTM running NINA
PL Focuser
PL Rotator
ZWO Filter wheel
EdElliott57 0.00
System 1 - @Starfront
ZWO AM5
Askar FRA500 w/Reducer
ZWO ASI6200MM Pro
ZWO 7-Filter Wheel with ZWO LRGBSHO
ZWO Focuser
WO Uniguide 50
ZWO ASI174MM mini guide camera
PPADVGen2
Wanderer Astro FlatPanel EC4
Wanderer Astro Rotator Mini V2
ZWO ASI662MC Pier Cam
Mele Quieter 4C Mini PC w/N.I.N.A.
System 2 - @Home - Edited 06/15/2025
(New) Sky-Watcher EQ8-R Pro on its Pier-Tripod - (Old) SkyWatcher Wave 100i on iOptron Tri-Pier
(New) Celestron EdgeHD 11 - (Old) Askar 120 APO (Have Reducer and Flatterner)
HyperStar V4
ASI2600MC Pro and ASI2600mm Duo Pro
PrimaLuce Esatto 2 inch for prime or reducer focus, ZWO EAF for HyperStar
ZWO Filter Drawer
ZWO 7-Position Filter Wheel with ZWO Filters
Optolong L-Extreme Filter
WO Uniguide 50, Sometimes Apertura 75Q
ZWO ASI220MM mini guide camera
ZWO ASI676MC Planetary Camera
Terrans Industry PowerBox Pro V2
ASI Air Pro - not using now
Geekom AX8 Pro Mini PC w/N.I.N.A.
System 3 - @Home
Apertura 75Q Refractor
iOptron Tri-Pier
WarpAstron WD-20 Strain-Wave Mount
Filter Wheel/Drawer from System 2
Cameras from System 2
Pegasus FocusCube 3
Guiding from System 2
Reg_00 9.14
Teleskop-Service ONTC 254mm F4 Newtonian
ZWO 2600mm | Antlia V-Series LRGB | Antlia 3nm SHO Filters
ZWO OAG-L | ASI120mm mini
Feather Touch FTF2008BCR 2” Focuser
PrimaluceLabs Sesto Senso 2 Focuser Motor
Teleskop-Service GPU Coma Corrector
JTW Trident GTR Mount
Pegasus Astro Uranus
Takahashi Epsilon 130ED Hyperbolic Newtonian
QHY268m | Astronomik Deep Sky LRGB | Antlia HS 3nm SHO Filters
William Optics Unigulde 32mm | ASI120mm mini
ZWO EAF
ASG Tilt Cage
Deep Sky Dad FP1
iOptron GEM45
Shannon_Foye 8.73
Building 3
Takahashi TOA130
MoonLite NiteCrawler WR35
AP1100GTO-AE
QHY268M
QHY OAG
ZWO ASI220
Chroma 3nm narrowband
Astrodon LRGB
Pegasus PowerBox
Pegasus Meteo
ASI676 pier cam
Beelink SER8
SeanBoon 0.00
Here is what my system is
Building 1
Scope: William Optics GT 81 IV and the .8x reducer/flattener
GuideScope:  William Optics 50mm
Camera: ZWO ASI 294MM-Pro
Mount: ZWO AM5
Filters:  Astronomik L R G B and the 2c versions of Ha, Oiii, Sii
Flat Panel: DeepSkyDad
Pegasus PowerBox Advanced
PC:  Beelink (whichever one was recommended)
