The constellation Draco is entirely in the northern hemisphere, but the UI reports it as being in the southern hemisphere. Everything else seems to be correct, in particular the coordinates certainly are.
Francesco
I think I found a small issue with the UI of the new search feature. I was searching for dark nebulae in Draco, and I noticed this (see https://app.astrobin.com/search?i=qv5l8c): ![]() The constellation Draco is entirely in the northern hemisphere, but the UI reports it as being in the southern hemisphere. Everything else seems to be correct, in particular the coordinates certainly are. Francesco |
Thanks Salvatore! Also on the topic of searching, I noticed that if I search for text in forum by using not the “Quick search” bar, but the “Search all forums” one, I only get image results, not forum results.
Thanks, will fix this too. It's a redirect thing. You are getting redirected to the new search, but the param that indicates you're searching in a forum is not being translated to the new param structure.
That happens! Thanks for looking into it so quickly!
