Where can others see the description I added to my equipment? AstroBin Platform open discussions community forum · Astrogerdt · ... · 4 · 139 · 1
Astrogerdt 0.90
after a long time I have been quite reader on this platform, I finally want to publish my images here.
I have added one image to my staging area  as a first test. When adding a setup, I also added a description to my setup, to highlight some special points:
However, when I view my own image in the staging area, I can't see anything about that description.
Is this description only intended for private use to better identify the setup, or am I doing something wrong?
CS Gerrit
siovene
This feature is rolling out as part if the new gallery UI. Are you interested in trying it out early?
Astrogerdt 0.90
Hi Salvatore,
thanks for the quick response!
Yes, I would like to try the feature.
Over the coming days, I will hopefully find the time (and data) to publish some more images, so I can give the new feature a try.
CS Gerrit
siovene
Done! You have access to the new gallery experience.
Please read more about it here:
https://welcome.astrobin.com/blog/introducing-the-new-astrobin-gallery-experience
If you find any issues, please report them via email using the Help menu above.
If you need to turn it off, you can do so in your preferences.
Hope this helps!
Salvatore
Astrogerdt 0.90
Hi Salvatore,
thanks, I will check it out in the coming days!
CS Gerrit
