Plate Solving of a Video in an AstroBin Revision is interfering with user ability to click on the Play button. AstroBin Platform open discussions community forum · Alan Brunelle · ... · 9 · 158 · 0
Alan_Brunelle
I have set up an image post that includes the galaxy image on the top page of the post, which is plate solved, but then in Revision B, I have a video.  For some reason the video is plate solved and when one clicks on Revision B, the video pops up as expected.  Unfortunately, when a user hovers the mouse to go click the play button, the plate solve pops up and the Play button is no longer visible nor active.  So that renders the video inaccessible.
Help!
Probably a simple fix, but I could find no way to disable plate solve.  Not in the Advance Plate Solve page for the post or for the Revision.  Seems like turning plate solve off should be an obvious choice.  This would be also a nice feature because whenever I post a non-solvable image, AstroBin seems to spend an inordinate time trying to solve an image that is not solvable.
Thanks,
Alan
siovene
Looks like something I need to fix. I’ll do it asap.
siovene
PS: if you tell me which image of yours this is, I could fix this manually before I fix the issue in the code for the future. Thanks!
Alan_Brunelle
Salvatore Iovene:
It's still in my staging area.  Only one there. Can you access this?
siovene
Yes, I can, I'll take a look in the morning, thanks for waiting!
Alan_Brunelle
Salvatore Iovene:
Thanks Salvatore!  My only frustration will be when I find out this problem was due to something stupid I did.  It always turns out that way.
siovene
Hi Alan,
I found the issue and the fix is coming today.
Salvatore
Alan_Brunelle
Salvatore Iovene:
Hi Alan,
Salvatore
Hi Salvatore,
I noticed this morning that the issue is fixed, so posted the image and presentation.  Thanks!  Hopefully this helps other as well.  Was there anything that I did that uniquely broke things?  This was my first time doing such a presentation, as simple as it was.
Best,
Alan
siovene
Alan Brunelle:
You didn't do anything wrong, it was a bug on AstroBin that affected everyone who uploaded a plate-solveable image and then a video as a revision that happened to have a middle frame that would plate-solve successfully
Alan_Brunelle
smile
