Image revisions and mouse over effects AstroBin Platform open discussions community forum · Jan Erik Vallestad · ... · 2 · 115 · 2
JanvalFoto 4.51
I'm not able to edit the mouse hover settings correctly on my revisions for some reason, I'll try to explain in short:
I've posted A-B-C-D where A is the original image. I then change my final revision to B but I'd like image D to be the mouse hover image (The original image is not on the list). I am able to do  this in the settings, but the settings do not take effect. Only if I delete the original image can I get the updated settings to take effect.
Is there an explanation as to why this happens, does the mouse hover only apply to the original image?
The images are all of equal size/resolution, example: https://www.astrobin.com/eqxd1j/B/?_ga=2.207751442.1449183258.1709540681-902289561.1701549131
siovene
Hi Jan,
as your final image is B, you need to do this to the B revision.
If you do it via the Edit menu, you would affect the original image.
Do it as shown below!
Hope this helps,
Salvatore
JanvalFoto 4.51
Salvatore Iovene:
Hi Jan,
Hope this helps,
Salvatore
Ah, I've been using the dropdown menus at the top. Didn't think of doing it this way. As always, thanks for the quick reply and excellent help!
