Can't find a "share image" menu in Safari/iOS (modern interface) AstroBin Platform open discussions community forum · Rodolphe Goldsztejn · ... · 9 · 96 · 2
rodolgo-outlook 0.90
Hi
I believe the title says it all.
Did I miss anything?
Rodolphe
siovene
Both of these will do!
Thanks Salvatore,
However, I can't find the top curved arrow on my interface, see below.
Indeed the "standard" button at the bottom will work...
Minor issue, for sure...
Thanks
Rodolphe
siovene
Thanks, that’s weird. I’ll investigate today!
shirejedi 6.64
Could it be because the image isn't published yet?
siovene
No, works for me on iOS/safari for unpublished images too.
siovene
@Rodolphe Goldsztejn do you run any content blockers on Safari?
Ah! that's a good point!
And YES - deactivating the blockers made the button show up.
Thanks for the hint.
Issue closed smile
Rodolphe
siovene
Curious what kind of blocker you were using. If it’s a “block share buttons” blocker then dah, but if it’s something else maybe I can do something so this is not a false positive?
I use 1Blocker on iOS, and astrobin was already white-listed there. Deactivating 1Blocker solved the issue - it generally blocks adds, web trackers, and other nuisances such as cookie notifications, newsletter subscription, push notifications, marketing widgets…
