AstroBin/PixInsight plate-solving issue AstroBin Platform open discussions community forum · Joachim Stingl · ... · 19 · 276 · 2
Earandir 0.00
Apprx. 2 days ago I uploaded a retouched image of the Markarjan chain with a part of the Virgo cluster and other galaxies.
Standard plate-solving worked fine, but extended astrometry is active since 2 days.
Is it normal plate-solving with many deep sky objects taking THAT long?
I wanted to process this image:
https://www.astrobin.com/shwi18/B/
And tbh I´m not a pro with astrometry, but a simple beginner taking astrophotos with a simple DSLR and tele-lenses.
astrograndpa 13.55
definitely not.  close and reopen and start again…let us know.  -john
Earandir 0.00
Still no result although I edited some of the settings and restarted again and again.
Basic astrometry working fine, extended not….
In the meantime I uploaded a few retouched versions of other images which worked fine.
Seems, Markarjan and Virgo don´t want to be astrometered via me… ;-)
Earandir 0.00
Hm, all my wider-angle-shots of constellations take WAY too much time too…..
siovene
Hi @Joachim Stingl,
site owner here. I'll take a look in a little bit.
Salvatore
Upload the image on astrometry.net and see whether it solves it. By the look of it isn't the best rendering, too much black clipping and overall bad optics.
Earandir 0.00
Salvatore Iovene:
Hi @Joachim Stingl,
Salvatore
Mille grazie!
Earandir 0.00
Already done ;-)
Vroobel
I can see the same problem, after 10 days it still didn't finish.
https://www.astrobin.com/dy4yqx/
siovene
Hi @Joachim Stingl and @Vroobel,
I took a look and the job is running to completion for your images. However, for those that you mentioned, it's simply failing due to star detection not working out.
Please this FAQ entry here for an explanation:
https://welcome.astrobin.com/faq#failed-plate-solve
In the last paragraph it mentions the option to upload a sample frame that might help with the solution.
Earandir 0.00
Ok, thx, Salvatore.
Unfortunately I don´t have FITS/XISF-files because I´m taking the shots with a DSLR/DSLM.
I tried converting a DNG into FITS - lets see, what happens when using this for plate-solving…..
JethroXP 2.39
I've been having trouble too.  An image of the Coma cluster from six days ago still hasn't plate solved, and my newly uploaded IC2169 has been spinning for 2-hours.  I even uploaded .XISF files to assist.  Any idea what's going on?
Earandir 0.00
Still 3 of my images are plate-solving:
Two wide-angle-shots since 3 days (areas around the Pleiades and around M 33) both JPGs (.FITS would be too large because of 250MB each)
And one since 5 days now - already uploaded a FITS-file and plate-solving with this one….
siovene
@Jason Coon
The image of the coma cluster is failing at Astrometry.net. You could try to change the settings to use the SExtractor star detection, it helps often! Your IC2169 failed to submit, I think due to nova.astrometry.net being available right at that time. I'll fix the code that does that to schedule an image to retry if that happens. I restarted it manually for now, and it did solve at astrometry.net. The PixInsight solution should follow suit, check your notifications to see if you get a solved/failed email!
If you upload a XISF file to assist, that's only relevant to the PixInsight plate-solution, that happens at a second stage after the Astrometry.net has finished. PixInsight cannot do a blind solve at the moment, unfortunately.
@Joachim Stingl
The Pleiades wide-field actually solved with PixInsight, but apparently the annotations generation failed. I just restarted it. Generally, you can also restart a job yourself or change the settings using the Edit menu.
I'll be adding more detailed information about the status of a plate-solving job on the page soon!
Thanks,
Salvatore
Earandir 0.00
Solving of two images still running…….smile
siovene
Hi Joachim,
can you send me the links to the specific images please?
Tapfret 4.95
Hmm…haven't noticed a problem with AB's plate solving. PI's ImageSolver process on the other hand has been giving me problems recently.
Earandir 0.00
Salvatore Iovene:
Hi Joachim,
Buongiorno, Salvatore, these are the URLs to the specific images:
https://www.astrobin.com/twzmi6/B/
Earandir 0.00
19 days and plate-solving still running……
siovene
Hi @Joachim Stingl,
looking into it. Referring to the two links you posted above, seems like the first one crashed PixInsight, and the second one failed. I made the PixInsight server bigger and I'm trying again.
