ZWO CAA ZWO CAA Camera Angle Adjuster · Alain L'ECOLIER · ... · 3 · 190 · 1
alan47 0.00
From France, (google translate)
My Setup :
AM5-ASI2600MM-ASIAIR-EFW-EAF (CAA)
Until now, the meridian flip was going correctly with a perfect match between the image that preceded and that which followed the meridian flip.
Since I installed the CAA there is a significant shift between the image that preceded and that which follows the meridian flip.
Should the CAA be configured, if yes how  ?
Thank you
How far off is it? Can you show an example?
BrianThePrimate 0.00
This is a common problem with the CAA. While some shifting is normal, it shouldn't be too bad. Make sure everything is screwed and tightened in place so there is no slippage. Sometimes the weight of your imaging train causes slippage if things are not secured enough. Also, make sure your ASI app is updated. They just released a huge update last week that fixed bugs with the CAA. Not sure if any of this helps  your situation, but I thought I would chime in since I own and use the unit.
alan47 0.00
Here's a copy before and after the meridian shift.
It seems to me that the shift is significant.
