I have been having issues with wifi since I took the update. It works perfectly when I am outside near it but when I get inside I get transfer rates below 100kb and regular disconnections. It was never fast for me inside because my house has vapor barriers with a layer of aluminum but it was not that bad. i never had issues checking the images as they are taken from my couch before. Now a 3 minutes shot can take more than that to download. Has anyone else experienced wifi issues with this version ? |
Nope Try rebooting your internet |
Windows absorb a lot of signal. My setup is about 40 meters from the house, so I leave my tablet outside, against a window, so that I can check it from inside. It works rather well. Philippe |
I have had similar issues with my ASIair Pro at the very beginning with it 3 years ago. Ever since I changed the ASI-WIFI-configuration to "Station Mode" and implemented an additional unexpensive extender (im my case a TP-Link RE205) I 've got no problems with the transfer rate anymore regardless of the firmware version. The transfer rate which I use to have is between 3Mbit/s and 7 Mbit/s at a distance of about 10 meters from my telescope outside to my Ipad in the living room. To make it even more stable I also use a LAN-cable from my ASIairPro to the extender connected to it. CS Emanuel |
I have the ASIAIR+ and have had similar issues as Emanuel Bierdel. I now use it in station mode with a wifi extender about 10 meters from my setup. All works well with no dropouts.
I have never had good Wifi coveraage with the ASI Air Plus. And, lI nver had any luck getting Station Mode to work reliably. I solved this issue by adding a wifi extender right at my tripod, replacing the Air antenna with a terminator and addingt a wifi cable from the extender to the Air. Now, I can sit at my desk (100 feet away from rig) and access the air and do everything but a PA.
This quick and cheap swap helped my range. https://www.amazon.com/dp/B07XFZB62D?psc=1&ref=ppx_yo2ov_dt_b_product_details I have an Access Point setup in my field (ethernet cable ran from house to AP) and then the wifi carries the last 125 feet or so. No problems. |
Thanks for the link. Certainly worth a try.
I don't use station mode. But, I hardwire my ASIAir to a portable travel router, attach the router to the tripod, and connect wirelessly to the router. No need to remove the antenna from the Air. Has worked flawlessly. The router I use is: https://www.amazon.com/gp/product/B01N5RCZQH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 |
How about making a cantenna?
Tom Boyd: What transfer speeds are you seeing reported? |
Tom Boyd: I'll have to take note of that next time I'm up and running. Qualitatively, it takes 2-3 seconds to upload each shot from my 2600mc to my iPad... |
