Asiair + hub usb ZWO ASIair Plus · Francesco Ottonello · ... · 4 · 167 · 0
Ziofrancotto 0.00
I own a Asiair Pro and a Asiair Mini.
Normally I connect filter wheel and guide camera to the hub of a Asi 183MMpro, then the camera to the Asiair; I connect EAF and my mount to Asiair and the last usb port normally is used with a flash usb.
As I am waiting for Zwo CAA I will lack a usb port for usb flash.
Is it possibile to use an external usb hub with Asiair? If yes it should be powered with external source or is it enough through usb?
Rattle
Yes it works perfect.
bobthemac 0.90
I used an unpowered hub for a while, but found the entire system became more flakey. I'm thinking the power available for all the USB connection was not enough. I'd definitely go powered hub or not at all.
gnnyman 6.04
I got my ASIair256G a couple of days ago and tried an external (unpowered) USB hub as well - yes it works, but the stability is not 100% - it sometimes hangs for a while…
Georg
LorenzoSiciliano 5.26
I currently use a usb hub connected to one of the camera usb ports. That way I have a total number of 9 usb ports available, 4 on the asiair and 5 on the camera.
Everything works without any issues.
Ciao
Lorenzo
