Asiair Calibration Settings for Using and OAG ZWO ASIair Plus · Uhhjoe82 · ... · 55 · 1670 · 3
YES!!
I found out my default guide rate is is "0.5x sidereal"
it had nothing to do with the slew rate, which I was talking about before
interesting.
so I did:
2 x 0.82 [arcsec per pixel resolution] = 1.64
1.64 / 15 [sidereal rate] x 0.5 [guide rate] = 0.054
1000 x 0.054 = 54
Does that sound right? Just 54ms calibration step size?
if that's correct, that still doesn't tell me what max RA and DEC duration to use
is there another equation for that?
Joo_Astro 3.80
@messierman3000 please do us a favor and don't spam so many messages about every thought you have.
Concerning your questions:
interesting.
so I did:
1000 x 0.054 = 54
You forgot the brackets, so it's (2 * 0.82) / [b]([/b]15 * 0.5[b])[/b] * 1000 = 218 ms.
You shouldn't really have to change that, just set it to default or about 2000-2500ms.
It was mentioned here, I recommend reading it:
https://eastwindastro.blogspot.com/2021/02/
ddompe 0.00
Arny:
I had similar issues when I started out with OAG guiding, and resolved almost all problems for
my setup of
- EdgeHD11
- Asi220mm guiding cam
- Zwo OAG-L
- Asi2600mm/mc APSC image camera
- AsiAir plus
by
- using 3 second loop interval in guiding
- running guide cam in bin2 mode at 400 gain - otherwise the stars were too faint and be more often lost than tracked
really good consistent results. last night I managed to 0.2-0.3" guiding precision on ma AM5 mount
Arny
Thanks for sharing this info, I’m starting with this exactly same setup yesterday, and everything was great until the meridian flip really close to zenith… after the mount reached his rough position and attempted to approach slowly the target, the belt slipped and  the camera almost hit the legs of the tripier (landed on a cable that saved the day). I’m using a 5kg counterweight which I read is the maximum supported… what are you using? Does something like this has happened to you?
afjk 3.58
Outch - I never a belt slip - when its overloaded the torque gets too high and it cannot provide that. Leads to an ugly sound while trying to provide torgue and then self arresting itself at its position. Only happens in extreme positions though whean reaching 20kg max load.
they actually added a heavy weight mode in asiair which halfs söew speed and saves wear on gears and supposedly is better in really cold conditions.
Adding the 5kg counterweight is a must for heavy loads and fixed this issue and I never had it again.
Arny
