ZWO 6200MM and Filters ZWO ASI6200MM Pro · Stephen Jones · ... · 5 · 154 · 1
Stephen.J 1.43
GDay all
Is it ok to use mounted 2" filters or use 50mm round with a ZWO6200MM?  Ta
ChuckNovice 8.21
Yes. I use Chroma 2" mounted filters with a 6200MM and here's what a flat frame look like. The extreme corners do get corrected.
Ensure that the scope also support the image circle of full-frame.
(deleted)
bdm201170 8.64
my setup  : zwo 6200 mm with  chroma 50mm unmounted
   i recommend a OTA  with full frame , and M54  optical train to avoid vignetting
here is  the link yo my setup one with FLT 120  and   TAKA Q Baby
https://app.astrobin.com/i/44tvuu
https://app.astrobin.com/i/ns6i7s
Stephen.J 1.43
Appreciate the feed back and time for the image of the flat.  Some set up there Brian; amazing gear.  I will look at the 50mm unmounted.  Chroma though will have to take a back seat though..
Thank you for your time.
maze 1.51
6200 mm + 50mm unmounted.
That's the minimum way!
I also prefer to use M68 openings, but M54 works.
