ASI585MC settings ZWO ASI585MC · Joe Kent · ... · 12 · 522 · 3
Ikailsolo 0.00
Hello,
What gain / offset settings does everyone use for the asi585MC on deep sky objects?
I have read that unity gain is 252 with an offset of 8 but I seem to be getting very bloated stars on this.
Any help would be greatly appreciated.
Thanks,
Joe
GBF87 0.00
Hello, do you use an IR/UV or narrowband filter? The star size should not depend on the gain if the exposure is correct. I use 260-300 with narrowband filter or lower with UV filter alone…
小卡子 0.00
I generally don't exceed 180 seconds for a single exposure; otherwise, the stars are easily overexposed.
etmonroe404 0.00
Hey Joe, I have not noticed "bloated stars" (I was using 252 with no offset), but I have been using a field flatter too.  I just connected the camera to a Samyang 135mm F2 and I'll let you know  if I see anything different, if the skies will ever corporate.
I really don't think your issue is camera related. I use a 585 as my main imaging camera for solar, lunar/planetary and deep sky and it's been working great. My standard settings for deep sky are a gain of 275 and offset of 1.  An offset of 8 seems really excessive to me. All you're trying to do with offset is to make sure your histograms are not clipped on the left edge, that's all. Of course there can be many optical reasons for bloated stars such as imaging with an achromatic refractor or not using a UV/IR cut filter, even with an ED or APO refractor. Over exposure can be a cause as well, my subs rarely exceed 30 sec. The longer you go on each sub the more bloated your stars will be.
WhooptieDo 10.40
Offset should not be determined by looking at the histogram solely.
Offset needs to be determined by looking at the bias frames.    In pixinsight, under processes, you can use the statistics function.   If any pixel is a zero value, then your offset is too low.   I went through the process with the 585MC and actually ended up with an offset of 8 as well.    My guess is you're not very well calibrated, and probably clipping some data, and maybe you're making up for some of it with a higher gain.
On the original topic, I'm currently playing with an uncooled 585MC and Roki 135.    At gain 100 I was managing 2 minute exposures, but 3 min were just a bit too blown.  My SQM's are just under 21 here so plenty dark.   Since I'm running an uncooled sensor, my biggest factor is overcoming dark current.    Again, alot of testing and toying around, but I've found above 100 the gain is just wayyyy too high and blows out the entire image wayy too easily.    I went to gain zero and I'm able to run 10 minute exposures right now.    I seem to be overcoming the dark current much better, but I haven't ran the numbers yet.     Can report back later.
Brian Puhl:
@ I don't find that to be the case but then again my subs are short. it is important to mention that you need to be at a gain of 252 to benefit from HCG mode where the read noise drops from a bit over 4 e-RMS to about 1.6 e-RMS. At the same time dynamic range pops back up to 11. Anyway, glad you're diving deep into this camera. I think it's a great option for those who really can't afford some of the expensive options or who need versatility in just one camera. I look forward to the results of your study.
Ikailsolo 0.00
Thanks all,
I'm imaging with a Samyang 135 @ F2.8 and 120sec exposures.  I will try with a lower gain to see what difference that makes…
Joe
Corcaroli 2.41
The recommendations are a little puzzling: first I used a gain of 252, but the pictures were over exposed and the stars bloated, despite short exposures. Finally, I got good images with gain at… zero !
Philippe
nfol 0.00
Sorry to be ignorant, but what does "offset"  mean in this connection?
Niels
Philippe Barraud:
The recommendations are a little puzzling: first I used a gain of 252, but the pictures were over exposed and the stars bloated, despite short exposures. Finally, I got good images with gain at... zero !
Philipp, how are you looking at your images and what is the format? A .fit format image that's not stretched will never look over exposed under normal circumstances.
N Foldager:
Offset is a setting that all astronomy cameras have. In simple terms, adding offset prevents clipping in the low end, think of it as shifting the histogram to the right.
wynypyc 0.00
Un saludo a todos  llevo gastando bastante tiempo  la así 585 mc  yo no supero estos parámetros la ganancia 100 exposiciones  210 s tomas suelo hacer entre 20/40 y también realizo  30 Dark filtro optolong L-eNhance
los resultados son también decentes bajo un cielo Bortle 9
La cámara no es refrigerada en un principio sabemos que no es para hacer este tipo de fotografía pero se defiende muy bien
Otra cosa es el procesado que hay que dedicarle tiempo
Hay tenéis algunos resultados
IC 1805-unknownObject-RGB-session_1-St222_stretched_GraXpert1-PSESTRELLAS2-estrellas finas.jpg
