ASI585MC non-cooled vs ASI585MC Cooled ZWO ASI585MC · Clayton Ostler · ... · 26 · 899 · 7
This topic contains a poll.
Is a cooled sensor that much better than a non-cooled, "For this case assume newer sensory technologies with zero amp glow, and the user limiting exposure times to under 60s"
I am not sure
I really doubt it
Absolutely and I can prove it
I think so, but I dont really know how much difference.
DanWBR 0.00
Clayton Ostler:
I own both the cooled and uncooled versions and the bottom line is, in cold temps there really isn't much difference. On hot summer nights there is a huge difference with the uncooled version being almost unusable.
Good to know. When you say unusable, have you found a sweet spot on max exposure time that will work?  Would 60 or even 30 second exposures work?
It is not unusable at all, as I'm using it at 30 C ambient temperatures and getting good data. Check my southern pinwheel photo, I spent less than an hour on it.
Clayton Ostler:
It all works, the problem was that the noise level was just having an impact on my final results that I just found to be unacceptable for my setup and conditions. I am shooting under bortle 8 and I'm sure that had an impact. Temps were in the 90's, I don't know what the sensor temp was but I'm sure it was up there. It was at that point that I decided to go cooled. Don't get me wrong, the 585 is a great sensor cooled or uncooled. You are just going to have to work harder in the really hot weather to get a good result. It's pretty much like shooting with a DSLR at that point.
