Good evening After a First "not so good" galaxy season I am about to swap the Edge for the RASA and I found myself confuse "again"… I was running the 533mm pro at gain 100 on my edge. Never thought about it much, was good enough for my 1-2 min exposure doing galaxy on a slow system. But now with the rasa I want maximum dynamic range. What would be the downside tonuse gain of zero instead of unity ? K |
Running a lower gain improves the full well and dynamic range, at the expense of noise. For reference, I have a RASA 8 with a 2600mm and I shoot from B7. When shooting narrowband (Ha, Oiii), I use Gain 100 and 300s exposures. When shooting broadband (RGB), I use Gain 0 and 30s exposures. I also have a LPS-P2 which I use for Luminence. For this one, I use Gain 0 and 60s exposures. |
When you have a very high photon throughput (with RASA, for example), using a low gain can be a good idea without much penalty. A low gain is accompanied with high readout noise. A gain lower than unity gain (1 ADU per electron) further brings quantization noise. These are the common disadvantages of low gain. However, when you have a very high photon throughput, you are guaranteed to have bright image background (unless you use unreasonably short subs, or you use narrow-band filters). When the image background is bright, the noise would be dominated by photon noise. Under this circumstance, read noise and quantization noise are no longer issues. |
Readnoise will go up. With F2 and longer exposure you can however overcome that, so the background will limitate that. With narrowband you probably will not have a good result with gain zero. The images will have these "lines" and the read noise will be visable a lot. (At least at dim objects) to be honest the difference in fullwell and dynamic range is not very huge compared to gain 100, so its not very an adventage |
Btw you better use gain 101. I know some instances where the unity gain is shifted by 1 or 2 values. Just to make sure you really hit the hit where it shits into unity
