How to use ZWO ASI 385MC ZWO ASI385MC · Avilla · ... · 58 · 711 · 13
astro-passion18 0.00
US coté est ou ouest ?
donc si vous regardez le ciel à l'oeil nu en fin de journée,  vous voyez bien le croissant de lune?
avilla54 1.20
andrea tasselli (andreatax)
Can we see what is attached to the camera, if anything. I mean, just the camera not the barlow or the scope, just the camera and whatever else is screwed onto it?
*** Sure. I see the 'small dot of light as pictured above without the 1'25 adapter 20250202_183215.jpgon, and with it on, I see nothing. 20250202_182951.jpg***
avilla54 1.20
mario:
*** East coast. And yes, I can see the moon ***
Can you see anything when the lens is on (2nd pic)? Point it to the ceiling and move the lever to focus, if anything appears on the screen.
avilla54 1.20
*** Yep, I get a very clear imagine with the lens on outside of the telescope. ***
So the camera is working all-right. That's a start. So the main problem for you is focusing. Ignore the barlow for the moment being. Do you have an adaptor to fit the camera with 1.25" adaptor onto the scope (1st pic)? You should have been given one with the scope.
Also, do you have an eyepiece?
je vois vos photos elles ne sont pas de bonne qualité l'objectif n'est pas propre ou ça vient de moi,
votre adaptateur 1"25 est équipé d'un filtre ? qui n'est pas non plus propre à mon avis
pour la lune vous voyez bien le croissant uniquement  donc vous devez avoir la même chose sur l'écran
avilla54 1.20
*** I have adaptors, but they don't fit the camera. The telescope also came with an adaptor, but it doesn't fit the camera. I have an Askar 103 APO. I think I'm going to need to buy one. Any recommendations? ***
avilla54 1.20
*** Yes ***
avilla54 1.20
mario:
*** I know, I need to clean it. And yes, I saw the crescent moon through the camera, but the camera obviously wasn't working properly because I couldn't see the sky around it if that makes sense? ***
Avilla:
non tout cela n' a pas trop de sens!
normalement un adaptateur 1"25 est fournit avec la camera
Avilla:
*** Yes ***
*Now, if you put the eyepiece into the scope and point it to the moon can you focus on the moon clearly? You should see craters and such. If you do then you replace the eyepiece with camera once you get a 1.25" to 2" adaptor. You should already have a 2.5" to 2" adaptor with the scope, if I'm not mistaken.
Any will do, Amazon first port of call.
avilla54 1.20
Avilla:
*** Yes ***
*** Yes, I can. My question would be is it normal to see the inside of your telescope tube while imaging? The picture I sent above (with barlow attached) is what I see viewing anything. Should the image be that small? ***
This is what you should have and how it should be assembled together, with the focuser racked all in (but it needs to be way out).
avilla54 1.20
Avilla:
Avilla:
*** Yes ***
*** Type your reply her ***
mario:
Avilla:
*** The adapter did come with the camera. I'm saying I can't see anything out of the adapter. I tried using a different adapter and holding it away from my telescope, and I got a clear image, but once I put it back in, the image became extremely small. ***
Avilla:
*No way. First off, remove the barlow. The view of the moon (in this case full) is shown here below with your scope and camera:
avilla54 1.20
*** Exactly, which is how I have it, I have both the 2 inch and 1'25 adapter on, and when I add my camera, i'm getting a screen with color but no image. Like a blanked out screen but the color changes depending on what I'm pointing at. Fcosuing doesnt work, so what am i doing wrong? ***
Avilla:
*** Exactly, which is how I have it, I have both the 2 inch and 1'25 adapter on, and when I add my camera, i'm getting a screen with color but no image. Like a blanked out screen but the color changes depending on what I'm pointing at. Do i take the 2 inch adapter off? ***
*Can you fit the camera with the 1.25 nose-piece into the 1.25" adaptor? If you can you are in business. Your problem is to focus because I suspect you are way out of focus.
avilla54 1.20
Avilla:
*** Yep. I've tried focusing but it still shows the blanked out screen with the color changes as you move the telescope around.  ***
Incidentally, if you can see the moon through the eyepiece then you know you can focus the scope. If you do while tracking the moon in the sky the next step is to replace the eyepiece with the camera.
avilla54 1.20
*** All I have is a blank screen with a histogram that won't move. I don't get what I'm doing wrong ***
c'est votre mise au point qui ne va pas je confirme,
  la molette réagie bien le frein n'est pas mis  le tirage n'est peut être pas suffisant (ajout de bagues allonges)
avilla54 1.20
mario:
*** Camera  and telescope are both in focus. I'm wondering if I have a faulty camera or something.  I dont think im doing anything wrong, and it shouldnt take 5000 adapters to make this thing work.***
