Hi everyone,
Dark flats are most of the time useless.
I suggest to read the paper that Siril staff wrote on this
(Sorry this is the french page, I guess the english translation is somewhere in their website)
https://siril.org/fr/2021/12/stop-%C3%A0-la-mode-des-dark-flats/
In a nutshell, they only recommend darkflats for very long flats (over 10s) or for cameras with very strong ampglow.
So most of the time, a masterbias is suffiscient enough and you save a bit of processing time if you had produced one with your dark librairy.
Edit: Here is the english translation :
https://siril.org/2021/12/enough-with-dark-flats/
I would be very careful about not using dark flats--note in thatarticle they do say be careful, you should verify yourself that it is okay.
But lets look at data. Here is my data for the ASI2600MC Pro, I cool to 0C to limit dark noise. This plot shows single exposures in the dark, the shortest exposure is the bias, the others would be called darks. All but the one marked continuous are one-off single exposures. What I am plotting is the average signal value over the bias/dark, so this is the bias signal plus any thermal contribution. All were set to 50 bias, which as you can see gives about 500 adu--this camera gives 10X adu for whatever bias is set. You can see the shortest exposure, the bias is a bit odd, sometime higher value than somewhat longer times. So if you use the bias as a dark flat it will be somewhat wrong unless it is the same exposure as the bias. Your flats will not correct to give you a nice flat field with this camera using a bias as your flat dark. Further, anything longer than 0.1 s increases the average value of the background, so anything over 0.1 s with this camera must use a dark with the same exposure--and as you can see it gets more sensitive with longer exposures. For this reason with this camera I would not recommend more than 1 second exposure, it is just too sensitive. And it is worse than that, taking images continuosly, as you would to average your dark/bias or your lights increases the average value. I believe this is due to sensor heating, despite cooling to 0 degrees, the instantaneous temperature of the sensor is higher than if you took a single exposure. So take your dark flats at the same exposure and with the same wait time between frames as your flats--if not your flats will be poor. This is my experience, match the dark flats and flats for good flats, it doesn't work well otherwise with this camera.
This is a very low noise camera, I would suspect other modern CMOS cameras will be similar, and indeed, others have reported the bias signal is often odd compared to any other exposure. Don't use a bias for a dark flat or a light unless you have proven it is okay.
Note, this is just looking at one aspect, the average level, there may be many other reasons not to use a bias.
Rick
