Redcat 91 WIFD vs the mighty Takahashi 106EDX4 William Optics RedCat 91 WIFD · Rabeea Alkuwari · ... · 8 · 471 · 0
RabeeaCaptures 4.44
Hello All,
I'm in the process of buying a new wider field scope and ofc my eyes were on Tak 106EDX4 based on what real world results photographers are posting on this site. But its an expensive scope so I did my research and my eyes turned to the Redcat 91 and its flawless spot diagrams. My question is that is the redcat now factually "better" than the takahashi? or do telescope manufactures exaggerate their in-house testing for marketing purposes? what I mean is that is there something I'm missing on how william optics are displaying their spot diagram data to make it look so flawless? are they displaying it in any different parameters than what's on the Takahashi official site
for my case I'm looking for the best telescope in that range of focal length money can buy and would appreciate some guidance in this matter.
umasscrew39 13.55
I would be comparing the Redcat 91 WIFD to the Tak FSQ 85 EDX- of which I had a Baby Q and still have the Redcat.  I used both in the same permanent setup with a ASI 2600mm and ZWO 7-position filter wheel, piggybacked on a C11” seated on top of an AP1100 mount.  Images from both scopes were comparably the same to me in detail and color.  However, I had two issues with the Baby Q that convinced me to sell it. One, on certain bright stars, you will get an hourglass like shape (I did post this as a topic on a forum here and how to fix it) that some may find annoying.  Two, the bigger problem, was that the focus draw tube eventually started to sag, causing the autofocus motor to stick.  Thus, it was impossible to get the scope to focus.  This occurred because of the poorly designed focal tube that is essentially attached to the main body of the scope with a piece of teflon glued to it.  Apparently, the glue eventually detached due to the weight of the accessories.  This occurred only after having the scope for 3 years.  It is also possible that heat in my observatory during the summer contributed to the glue issue.
The design of the Redcat avoids the sagging and no funky star shapes on certain bright stars.  Now, I have only had this scope since it recently became available, so time will tell if it has any issues.
So, based on my experience with both scopes, I would go with the Redcat based on quality of the images and cost.
aabosarah 9.31
You might want to look at the Ultracat 108 that is being released soon. That would be a lot closer to an FSQ106 than the RC91.
https://williamoptics.com/products/ultra-cat-108-wifd
Personally I would love to see WO release an Ultracat 130 at f/5.
RabeeaCaptures 4.44
Ashraf AbuSara:
I didnt know that was actually in the pipeline - thanks for the heads up
my question still stands though on how william optics displays their spot diagrams
RabeeaCaptures 4.44
Bruce Donzanti:
Redcat does seem in terms of build quality a soild purchase - in the middle east we do get extreme temperatures so its good to know how most of redcat delicate internals are relatively isolated from external weather. though another comment suggested that a redcat 108 is in the pipeline so I'm now more inclined to wait for that release.
aabosarah 9.31
Rabeea Alkuwari:
Ashraf AbuSara:
I would take spot diagrams with a grain of salt. Definitely would not use them to compare one manufacturer vs another. Just primarily that the manufacturer is promising well corrected off axis and on axis performance upto and beyond a full frame sensor.
KGoodwin 4.71
It's gotten to be so difficult to shop for scopes these days.  There has never been more out there in terms of both variety of scopes as well as images here on Astrobin to compare them, but with the advent of tools like BlurX it has become increasingly difficult to compare using the results you see here.  Yes, you can still discern the differences if you spend a lot of time studying images, but it would be great if there were also a place to browse uncorrected/minimally processed images so that you could compare the optics or other equipment rather than the processing.  Looking for EAA images is sometimes helpful, but there's usually a limited subset of scopes that people tend to use for EAA.
Alexn 12.25
There are two things that need to be considered - optical technical quality (spot diagrams, p/v graphs, Strehl rating etc) but then there is the way optics render a target… This can be a really unquantifiable quality that no technical diagram or test will ever be able to show you.
The Redcat 91 and future Ultracat 108 could be technically perfect (I've not used one… I can't say) but the way a Tak FSQ106 renders an image is really something else…. I had a FSQ106N (back in the day) and it was undeniably exquisit - it had its optical flaws, lets not imagine for a second that they are without their issue… the hourglass shaped diffraction on bright stars was annoying to say the least, but it was also kind of like the calling card of the FSQ….)
There's more to a scope than spot diagrams.
dweinbrenner 4.79
Ashraf AbuSara:
I read there will be a Mega-Cat 130 in the future.
