TOA-35r reducer for TOA-130 performance on Full frame sensor Takahashi TOA-130 · Ashraf AbuSara · ... · 13 · 322 · 15
aabosarah 9.31
I am considering utilizing the Takahashi sale and getting the TOA-35 reducer for the TOA-130. I know that its performance is not as good as the 645 flattener, but I wanted to see how well it performs on a full frame sensor with small pixels like the IMX455. Can anyone post raw subs acquired with this combination on a full frame sensor or maybe a 3x3 square mosaic of unprocessed subs?
Thanks.
t-ara-fan 0.90
I have this one  https://takahashiamerica.com/products/takahashi-toa-35-reducer-for-toa-130  I call it the TOA-35. Is that what you meant?
Camera is ASI6200MM. Filter is Antlia 2" 3nm Ha.
I have never addressed tilt, it didn't seem like a problem. The scope is a TOA130-NFB, ZWO 7x2" EFW, ZWO OAG-L/.
Rosette_Nebula_HA_2022_11_19_05_42_05_24_90C_900_00sec_204stars_0009_a_eccentricity.jpg
aabosarah 9.31
Thank you for this! The star square image doesn't look bad at all, but was this a sub, or a stack with 2x drizzle? Because a FWHM 3.591 with an image scale of 1.11"/px makes that sub have a FWHM of almost 4", which seems really poor.
t-ara-fan 0.90
This was a single 900 second sub. Not calibrated, just ScreenTransferFunction and HistogramStretch so it was not all black.
Hmmm it might be been bad seeing.  I will look for a pic from a different night.
t-ara-fan 0.90
Here is a different night.   FWHM is 2.146 pixels, better than the 3.591 in the above example.
Soul_Nebula_700mm_HA_2023_11_26_23_10_11_20_00C_600_00sec_485stars_0024_eccentricity.jpg
aabosarah 9.31
Looks maybe like a mixup? Because these are the same frames you posted initially.
Andys_Astropix 14.17
Warning! The TOA-35 reducer on a TOA-130 does NOT produce an image circle sufficiently large enough to cover the IMX 455 sensor.
I have one, which was great when I had the CCD KAF-16200 camera, but when I upgraded to the Atik APX60, the vignetting was terrible!
I've had to abandon using it, and reverted to my TAK 67 flattened instead, which is perfect. smile
Andy
t-ara-fan 0.90
Ashraf AbuSara:
Whoops. OK I edited my reply above with the second set of pics with the better FWHM.
t-ara-fan 0.90
Andy 01:
Andy
Indeed. The corners of the FF sensor are quite dark.  See the pic below.
The spec from Takahashi says 44mm image circle, but if it is at only 20% illumination that isn't very good.
There is still a place for this 0.7x flattener:  I was trying to shoot the Squid Nebula (very very faint) at f/7.7 1,000mm and it was just way too dark unless I got tens of hours of data.  At f/5.4 with this reducer I will get twice the photons per pixel per hour.   I have the FLAT67 too, which is what I usually use. But when I try the Squid again next year I will use the reducer.
I am not disappointed in this reducer. A lot of people think putting a chunk of glass at the camera end of a telescope will somehow make the front end grab a wider brighter cone of light. That isn't how it works.
aabosarah 9.31
Andy 01:
Andy
Ooof . That is a lot of vignetting. How does it look after applying flats?
Supro 4.37
Andy 01:
Andy
that's the same reason I bought and then sold the TOA-35 reducer. the illumination dropoff was steeper than I thought it would be. I moved back to the 645 flattener. (so sharp and no noticeable vignetting on the imx455). While I like the idea of the faster TOA-130, I like that 645 more.
Habib_Sekha 1.51
My experience is that what is left as useful is somewhere between a full frame and ASP-C format.
A lot of the vingetting can be removed by calibration frames but the stars in the corners are horrible.
For faster light gathering at ASP-C it is fine.
aabosarah 9.31
Thank you all for the feedback. I will stick with the 645 0.99x flattner.
Here is a sub from my TOA-130 using the TOA-35 0.7 reducer, on my IMX45 camera, like t-ara-fan 's image above, the vignetting is terrible. On my former APS-H camera with the smaller KAF 16200 sensor, though, it wasn't noticeable.
