A way to fix the so-called inverted lighthouse or hourglass effect caused by the Tak FSQ-85 EDX on some bright stars Takahashi FSQ-85EDX · Bruce Donzanti · ... · 31 · 2130 · 8
Genoafire 0.90
Marc
 I didn’t get a chance to test the FSQ-85 last night.  Before starting the image sequence I noticed the outer covering for the power cable going to the ZWO ASI6200 camera was torn and needed to be replaced. I didn’t want to risk possibly frying the camera if the actual wires running inside were also damaged.   I replaced the cable today, but now the clouds have moved in  🤦‍♂️. I will test the retracted dew shield theory as it relates to the inverse Lighthouse effect as soon as I get clear skies again.
Bob
Genoafire 0.90
As a follow up to my earlier post on the possibility of the fully extended Dew shield on the FSQ-85 causing the inverse Lighthouse effect :
I finally got out during the break in the clouds to try out the FSQ – 85 and the new .73X reducer with the dew shield only extended about an inch versus fully extended.  I imaged 2118 the Witch Head nebula using two minute exposures and included  Rigel in the frame.  I also imaged comet Ponds-Brooks that is now low in the western sky for us here in Northern Nevada.  I only managed to get four 2 minute  light frames of the comet before it went below my preset photography cut off of 20° horizon.  Looking at the results I don’t see any inverse Lighthouse effect on the stars surrounding the comet image., but those stars are not that bright.  Looking at the Witch head finished stacked image in Pixinsight the inverse Lighthouse effect is still there on Rigel and a few of the brighter stars- even with the shield only extended approximate 1 inch.  But it does not appear as extensive on the lesser magnitude stars as it did when I imaged the Witch a few months ago with Rigel in the field of view.  Since my telescope is in a domed observatory and I don’t have a huge amount of light pollution in my neighborhood I personally plan on  extending the dew shield only halfway in the future.  I do have a dew heater on the scope just behind the front front objective lens assembly.
Sorry this is not a more precise scientific analysis.  I can only conclude that the dew shield being fully extended does make somewhat of a difference as far as the Inverse  lighthouse effect on the brightest stars.
Bob
Overcast_Observatory 19.90
You may be able to reduce this effect by using an aperture mask.  It will slow your scope down a little bit, but should improve these artifacts and give all your stars a more crisp edge reducing the slight flaring. I did this a while back when I used a WO scope that produced the iron cross shape stars.
codwyer 0.00
Yeah, this was the way to limit the iron cross effect on older star 71 scopes and all the recent 70mm F5, 90mm F5 and the new 60 mm quads that have the same effect...corrector small and too far up the tube to prevent mechanical vignetting diffraction. Fsq 85 has a tiny corrector. Stopping down the front lens aperture is the best way to deal with this, but it will slow the scope up a lot. The cat eye bokeh that causes the inverse lighthouse dark wedges seen here in a camera lens. When you look down the fsq 85 from the front and move the scope, you can see how much of an almond shape forms compared to a normal triplet.
StewartWilliam 5.21
Colm O'Dwyer:
I’m sorry but this is totally wrong, and not the reason for the Lighthouse effect at all on this scope, and it s a Quad, not a triplet, it’s made of two sets of doublets one at the front and one correcting set near the back, this forms the quad flatfield design.
codwyer 0.00
Yes it is the reason. I know it's a quad, and if you read the post carefully, you ll see that I stated a triplet doesn't form as much of an almond shape when you look down it and move the scope from side to side, as happens with a fsq 85. With the focuser end unobstructed obviously.
Vignetting diffraction is the fundamental reason why the fsq 85 forms the inverse lighthouse beam, dark wedges etc. whose position (line bisecting the centre of the star and the collinear wedges) is orthogonal to the centre of the frame, all around the frame.
I know the design and the nature of the optics very well, a long focal length doublet with spaced doublet towards the back, a modification of the original petzval design.
StewartWilliam 5.21
Colm O'Dwyer:
Well it’s funny really as I owned this scope for 3 years, and had the lighthouse effect and solved it, the issue was a rubber O ring around the front element, that the two ends of it were not meeting and there was a tiny gap, this caused the effect, and I very carefully managed to fill that tiny gap and the issue went away…
but an aperture mask probably would have worked too as it would have covered this issue…🤷🏼‍♂️
