Upon opening PI this morning, I received an update notification for Utilities. I let it update and now Graxpert doesn't work. The following error pops up: run --execute-mode=auto "C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js"Processing script file: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js*** Error: Signature verification failed for 'GraXpert': Invalid code signature: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js |
DavesView: Upon opening PI this morning, I received an update notification for Utilities. I let it update and now Graxpert doesn't work. The following error pops up: run --execute-mode=auto "C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js"Processing script file: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js*** Error: Signature verification failed for 'GraXpert': Invalid code signature: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js *Hi David, I had the same problem. Temporary you can go to: C:/Program Files/PixInsight/src/scripts/Toolbox/ and rename Graxpert.xsgn file to something else (i am not behind computer but I think this is the filename, its only another Graxpert.* file besides .js). This will disable verification and allow you to use GraXpert.
Hello. I had the same problem but I have found the solution with the help of my friend Régis also in Astrobin. in fact, there’s a new version of the software on the Pixinsight website since January 19. You just have to delete your old version and to download and reinstall the new one. After, there is no problem and you can use easily expert and all the scripts of the toolbox. I hope that will help you.
Sorry for my poor English. Jérôme Gaillard France
A moderator moved this to Graxpert forum from PixInsight forum. The software was PI. The notification to update and the update was PI. Graxpert is called from PI. Graxpert worked... PI didn't. The fix was in PI. Not complaining, but rather explaining the error of my ways. lol  |
Reinstalling the latest version of PixInsight fixes the problem, too.
Jure Menart:
and rename Graxpert.xsgn file to something else (i am not behind computer but I think this is the filename, its only another Graxpert.* file besides .js). This will disable verification and allow you to use GraXpert. *** very helpful thank you very much***
Jure Menart:
and rename Graxpert.xsgn file to something else (i am not behind computer but I think this is the filename, its only another Graxpert.* file besides .js). This will disable verification and allow you to use GraXpert.i I tried to change the name, but it disappeared from the toolbox in Pixin. Can you please give an example of your rename?
abdullah alharbi: I tried to change the name, but it disappeared from the toolbox in Pixin. Can you please give an example of your rename? I have since upgraded PI. Apparently what I renamed it to has been changed back to the original name, and I can't remember what it was that I changed it to. Perhaps Jure can enlighten you. Might be best to just upgrade PI.
DavesView:
I have since upgraded PI. Apparently what I renamed it to has been changed back to the original name, and I can't remember what it was that I changed it to. Perhaps Jure can enlighten you. Might be best to just upgrade PI. it seems like I was changing Js not the other one that's why it disappeared, it works fine now, thank you 🙏
