I'm starting to feel a little more comfortable with N.I.N.A. and I'd like to understand more of the information provided. Here's the HFR box at the top of the screen. Some is self-explanatory, some not so much. I'd like some help understanding the data. I'm using an SX694 mono camera with a filter wheel on an Esprit120mm refractor. The information below is from a 180 second exposure (Luminance). What is this information telling me about the image and/or equipment set-up, image quality and exposure etc.? Width 2750 Height 2200 Mean 1969.88 SD 64.31 Median 1969.00 MAD 12.00 Min 1878 (1x) Max 32481 (1x) #Stars 58 HFR 2.13 Bit Depth16 HFR SD 0.33 Gain – Offset – Hank |
5
Hank, as far as I understand, these mean the following: Width, Height: The dimension in pixels of your light frames (images) Mean: mean pixel value in your actual frame Median: median pixel value in your actual frame SD: standard deviation of you pixel values MAD: mean absolute deviation of you pixel values Min: minimum pixel value in your actual frame (number of pixels in your image with that value) Max: maximum pixel value in your actual frame (number of pixels in your image with that value) #Stars: Number of detected stars in your actual frame HFR: half flux radius of your stars (similar to FWHM) Bit Depth: Bit Depth of your camera (16bit) HFR SD: HFR standard deviation Gain, Offset: Gain and Offset of your camera (unclear why no values shown) HTH & CS Chris |
3
SD = Standard Deviation of the statistical distribution of pixel values in the image MAD = Mean Absolute Difference, i.e. the absolute value of the difference between the model used to fit the PSF and the actual data Mean = Average of the pixel values of the image Median = Median of the pixel values of the image Max = Maximum value of the pixel values of the image Min = Minimum value of the pixel values of the image HFR = Average Half Flux Radius, i.e. the radius of the PSF where half of the photon flux is accrued across all detected stars in the image HFR SD = Standard Deviation of the HFR #Stars = Number of Stars detected Gain = Gain Offset = Offset |
Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13.
Most of these are highly dependent on circumstances – type of sensor, OTA focal length and focal ratio, seeing, light pollution, etc. As a simple example number of stars can go down dramatically as light pollution goes up, and as altitude of the target goes down toward the horizon. HFR (or maybe better FWHM if you use Hocus Focus as the focuser) is a little more constant indicator of focus quality and seeing. It's still quite difficult to compare to other and different equipment and circumstances but to some degree HFR will be in the low single digits, maybe 2-4 or so, but still it is best as an indicator of your situation (e.g. if higher one night than another probably worse seeing, or you did a worse job of focusing). Eccentricity (also requires Hocus Focus) is a measure of circularity of stars, which is an indicator of tracking accuracy. Anything in the 0.4 or even 0.5 or lower is good, as that goes above 0.5 there's usually some problems with tracking causing stars to be footballs. These measures (that I mentioned) are largely independent of target. Not completely, but the star detection does not pay attention to diffuse subjects. It's also worth noting that these analyses are aimed at auto-focus, and not at being comprehensive. If you (for example) compare FWHM from Hocus Focus with Pixinsight after the fact, you will see very different numbers. They will track relative (i.e. if you take two images where eccentricity goes up, PI will show it going up also) but not in an absolute sense. Pixinsight may for example detect literally an order of magnitude more stars with its deeper (and slower) analysis. As a general rule you want to compare all these settings to your own changes - whether equipment, procedure (e.g. autofocus), weather, etc. as an indicator of whether you improved certain things or not, and not get hung up on their absolute magnitude or trying to compare to others. |
andrea tasselli: Ciao Andrea, maybe I am wrong, I always thought that MAD was just the MAD of the pixel values of the image, as an alternative variability indicator to SD. Ciao! Mau |
Thanks, Linwood. I’ll try to relax and not get hung up in the numbers as “absolutes”.
Ciao Andrea, It depends. If it is referring to calculated PSF values I suspect it's the definition I gave above, if for the whole image then it is indeed Mean Absolue Deviation -> Sum(value - mean_value) /number of pixels |
Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13. I would bring you camera offset down a bit as 1878 is a bit high try and get I down to about 400-500 at most…👍🏻 |
AstroShed:Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13. Min values have nothing to do with offset. On top of that it's a CCD camera, offset is fixed as it is gain. |
andrea tasselli:AstroShed:Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13. Actually I think you will find that the offset has everything to do with the min value, bit I did miss the CCD bit so I will bow out… |
andrea tasselli:AstroShed:Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13. Explained better here… see the 3rd line down… Here's a screenshot of NINA during an imaging session. The numbers in the statistics window are for a Red sub from an ASI2600mm Pro. Your sensor will be different. I shoot LRGB at 0 gain and SHO at 100 gain, both with an offset of 20. I don't pay much attention to the histogram, just the numbers in the Statistics window, particularly the Max (x) number. The Min is based on the offset you set, showing the pedestal. The (x) after the Max I try to keep below 200, this is the number of pixels that are over-saturated. You can go as high as you like, but be aware you're blowing out those pixels. But you have plenty. The Mean and Median are telling you the ADU and I try to keep the Median above 355 at 0 gain and 287 at 100 gain. Attached Thumbnails |
AstroShed:andrea tasselli:AstroShed:Thanks for the replies. Perhaps a better question would have been - are the data what one should expect, on average? The target was M13. |
Just keep in mind (re obsessing over these) that 200 vs 500 is about half a percent based on 65535 full well. Reducing it is "right" but don't expect to see the difference (and do expect to redo your darks and dark-flats with any change in gain or offset). The vast majority of DSO data is on the far left side of the histogram, and with reasonable length exposures you are going to saturate the cores of some bright stars in all likelihood. Reducing exposure to save these cores will often yield a massive number of very short subs and may be more pain in that regard even if the result may yield slightly better star cores. Basically: Sweat the big stuff first. Get nice round, tight stars, in good focus, and always collect more data than you might think you need (because more data fixes many other problems). |
