Today I tried to update the TPA plugin and I got a messsge error that the update failed. I uninstalled the TPA and when I tried to install it back it also fails to install. I then uninstalled NINA and reinstalled it and the problem persists. I tried to manually install the TPA and NINA is not uploading it. What else can i do to fix this??
Hi Wanda, I read your comment and tried it on my own PC. It seems to work. What version of NINA do you use? I have NINA 3.1 HF2 Beta 006 (the current Beta version) installed. I usually use the nighlty builds, but at the moment there is only the Beta version available. Maybe you can try this one… Maybe you can update your state after this. CS Christian |
Thanks for responding. I am using the stable version 3.2 HF1. I used night builds until they were no longer available. I will wait a few more days to see if someone using the stable version chimes in, otherwise I guess I will start using the Beta versions and hopefully that will fix the problem. Will update if I go ahead and do so… CS, Wanda |
I assume, the stable version will be upgraded soon. The testing of the beta version is running quite long now. In the past, I had such problems with some plugins, too. They all were solved with the next update of either NINA or the plugins itself. I guess, this will happen very soon… |
