Thanks again for your work, much appreciated!!
Hi Steve, That’s a wonderful script. It will save me a lot of time. I noticed that some filters have 5-digit numbers in Astrobin, so I changed the value in line 914 from 9999 to 99999 so the filter number is not rejected. Do you think it’s possible to extract darks and biases information from Pixinsight ‘Master Dark’ and ‘Master Bias’ file types? I use a master dark library and a master bias library containing XISF files already integrated by Pixinsight, in order to save disk space. But, so far, the script cannot extract info from them. Thanks a lot for your work. Francisco |
Francisco Bitto: Hi Francisco, Thanks very much for your comment. I am working on a few bug fixes and other mods so I will look at it. It looks like there is a field in the Pixinsight Master header that gives the number of integration images, so it is possible. CS Steve |
Hi Steve, Sorry to report, I am still getting errors running this on a big directory full of images. Different error now though! Full output is attached. Hope this helps! Scott errors.txt |
Scott Denning: Hi Scott, Thanks. It seems the problem was how the .csv files were being read in. Have replicated it and fixed it here and with one other user. I have decided to make a few other requested mods before I release the next version Explicit support for SGP, beyond using the defaults.csv Support for Pixinsight master calibration frames. I pass the pre-release to you to test it you have time. Thanks again for your help Steve |
Wonderful! I will be more than happy to be a beta tester as long as you wish. Great work! |
Update 10th December 2023 I have just released the latest version of the script. There are quite a few stability and some feature changes, these are listed below. I am currently working to include Pixinsight generated Master files. Looking at how to be able to deal with these I decided to make major changes to my coding approach. Once released, what started as a hack for me, now carries quite a responsibility to get it right! The next release will include quite major changes and quite a bit of testing and I wanted this more stable release to be available. Many thanks all who commented and tested the script, particularly Ken Bates and Scott Denning. Please let me if you like the script, find any issues or have feature requests. CS Steve The script can be found here https://github.com/SteveGreaves/AstroBinUploader The release bundle can be found here https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.0.4 Version 1.0.4 6th December 2023 changes 1.No longer required to manually create configuration csv files. Checks if csv files exist and creates them if they do not exist. Default values can still be edited in csv files but also in the configurations dictionary at the start of the code. Default keywords changed to lower case To ensure csv edits don't cause issues the data read from files is: stripped of leading and trailing spaces keywords are converted to upper case to match FITS header keywords column names are converted to lower case to ensure code can work with them corrected data frames are saved back to csv files to format issues are resolved 2. Improved extract header function converts floats to 4 decimal places converts dates to format %Y-%m-%d, rounds input to microseconds to ensure conversion works creates a subset of the header data that matches AstroBin requirements 3.Sites.csv file latitudes and longitudes saved with 4 decimal places but processed to 2 decimal places to ensure the same site is not recorded multiple times. 4. Corrected issue with Bortle and SQM values not being updated correctly 5. Corrected issue with Keywords from .XISF files not being read correctly 6. Improved code to correct file data reading and saving logic 7. Runtime option to stop program if new csv files are created to edit them. 8. Corrected program logic related to import, access and storage of external parmeters. 9. Refactored code to improve readability 10. Updated docstrings 11. Works with files generated by both Sequence Generator Pro (SGP) and NINA (.FITS, .FIT, .FTS, .XISF) 12. Looks for filter in FITS headers and converts them to 5 digit codes used by AstroBin ( used to be four digit codes) |
New release of this script that contains major changes and bug fixes can be found here: https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.3 CS Steve |
Hi Steve, Thanks a lot for continuing improving your script. I've been getting some errors with the last versions, including V1.3.3. But that only happens in some folders, the ones that have only Light frames work OK. I've attached the .csv debug files to see if it can be of any help. LBN 535 180mm.zip Best regards, Francisco |
Francisco Bitto: Hi Fransisco, Could you also send me the .log file from the run. Thanks and best regards Steve |
Steve Greaves:Francisco Bitto: Yes of course, please find it attached. AstroBinUploader.log Thanks a lot |
Francisco Bitto:Steve Greaves:Francisco Bitto: Hi Francisco, Can you send your e-mail address to [email protected]. I can then send you a version of the code that I think resolves your issues. If it works I will then make a wider release. Best regards Steve |
Giving this script a try. It seems to walk through the directory structure I give it, outputting messages "Extracting headers from directory: \\M42\2022". After these "Extracting headers" messages it then outputs the message "Read Headers to DataFrame" and then quits without any files being written. I tried it with a –debug flag and no change. I have given it multiple directories of PixInsight-generated .xisf files that resulted from WBPP sessions. I have also tried it on .fts files produced from MaxIm DL. Same results in all attempts. I am running Windows 11, Python 3.13, AstroBinUploader 1.3.3 Any ideas what I might be doing wrong? |
Update: My acquisition software uses the value "Light Frame" for IMAGETYP instead of "LIGHT". AstroBinUploader converts it to "LIGHTFRAME" but it's still ultimately expecting "LIGHT". I manually changed the value to LIGHT on a test frame and that worked. I then got errors with the site-name that came back from the lookup (see below). I subsequently changed the site name in config.ini and now it all works. I think now I just need to figure out how to get the script to recognize "LIGHTFRAME" as a light frame rather than requiring "LIGHT". Message: 'Processing site: 颍上县, 阜阳市, 安徽省, 中国' Arguments: () — Logging error — Traceback (most recent call last): File "C:\Users\testuser\AppData\Local\Programs\Python\Python312\Lib\logging\__init__.py", line 1163, in emit stream.write(msg + self.terminator) File "C:\Users\testuser\AppData\Local\Programs\Python\Python312\Lib\encodings\cp1252.py", line 19, in encode return codecs.charmap_encode(input,self.errors,encoding_table)[0] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ UnicodeEncodeError: 'charmap' codec can't encode characters in position 60-62: character maps to <undefined> Call stack: File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\AstroBinUpload.py", line 213, in <module> main() File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\AstroBinUpload.py", line 181, in main summary_txt = summarize_session(aggregated_df, logger,headers.number_of_images_processed) File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\utils.py", line 545, in summarize_session target = site_details(target_group , site,logger) File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\utils.py", line 318, in site_details logger.info(f" Site: {site}") Message: ' Site: 颍上县, 阜阳市, 安徽省, 中国' Arguments: () Traceback (most recent call last): File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\AstroBinUpload.py", line 213, in <module> main() File "C:\Users\testuser\Downloads\AstroBinUploader-1.3.3\AstroBinUpload.py", line 194, in main file.write(summary_txt) File "C:\Users\testuser\AppData\Local\Programs\Python\Python312\Lib\encodings\cp1252.py", line 19, in encode return codecs.charmap_encode(input,self.errors,encoding_table)[0] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ UnicodeEncodeError: 'charmap' codec can't encode characters in position 97-99: character maps to <undefined> |
Hi Jeff , looks like you are sorting this out. Can I ask you run with the debug option activated and send the files to [email protected]. This way I can see exactly what is happening . thanks steve |
Update 1st October 2024 I have just released the latest version of the script. The code can be found here: https://github.com/SteveGreaves/AstroBinUploader and a release bundle can found here: hhttps://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.10 there are quite a few bug fixes along with following changes:
I have also update the readMe files to reflect the changes. Please read this first before to run the script. I think all you need to know is contained it the file. I hope that this is it! If you have any questions or comments please let me know. Hope you find this useful and of course: CS Steve |
Looks like an interesting tool. I'm not very into coding so I ask: Is it possible to use somehow the date of observation -12 hours to group each session by its starting date (e.g. I start a session tonight and it finishes tomorrow morning, I want the selected date for all the subframes to be 10/01/2024 and not half 10/01/2024 and half 10/02/2024) and also to customize what kind of information needs to be extracted (I want just the # of frames, the duration, the filter, the date -12 hours, the f ratio and the Bortle scale, without all the calibration frames etc. etc.). Thank in advance, Daniele |
Hi Steve, I used your script recently for the first time and it worked fantastically. This is going to save me so much time! Thanks for your contribution to the community. CS, Andrew |
No problem Andrew. Thank you for your kind comment. CS Steve |
Daniele Borsari: Hi Daniele, I will look at this when I next look to update the script. CS steve |
Hey @Steve Greaves Testing your script now - and it looks very promising. Thank you for making this!! One quick piece of feedback, as I am currently testing it against a large dataset. It would be great to see some counter or progress indicator here, when processing: ![]() |
Thanks Christian, I am glad you find it useful. iI have noted your request and will look at it, along with other requests, for the next update, CS Steve |
Hi @Steve Greaves, I tried to run the script but I get this error and there is no generated csv file. Do you know how to solve this problem? ![]() Daniele |
I've sent the log file to your mail, thanks in advance. Daniele |
