NINA - Safety monitor and Target scheduler Stefan Berg Nighttime Imaging 'N' Astronomy (N.I.N.A. / NINA) · Leonardo Landi · ... · 1 · 221 · 1
Leon87 0.00
Hi guys. I recently installed my own remote setup, at a facility that has independent roofs for each setup with the ability to manage them personally. I found several solutions online that involve Sequence Powerups triggers, and I tried to insert them into my basic sequence that uses a target scheduler container.
Below I put the way I would have set up the sequencer, using the custom events containers -> triggers of the scheduler. I would appreciate your advice on this.
image.pngI also put a link for the whole sequence down there.  Startup_Scheduler_end_NEW_NEW.json
alpha.leonis 0.00
Hope you changed your sequence since your message : safety should not be managed in the Target Scheduler Container.
Dot 4 : https://tcpalmer.github.io/nina-scheduler/sequencer/container.html#custom-instruction-dos-and-donts
