N.I.N.A. multiple instances with two identical cameras Stefan Berg Nighttime Imaging 'N' Astronomy (N.I.N.A. / NINA) · Werner Stumpferl · ... · 4 · 549 · 0
WS65 0.90
Hi community,
does anyone know or has experience with this ? I´m running two instances of NINA on a Laptop with different cameras but I want to change both rigs to identical cameras. Is this in gerenal possible ? What shows NINA … 2x the same cameraname for selection ? If yes, how can I identify the right camera for the right rig ? Or is there a USB-Limit because of identical names ?
thank you
Werner
Florin77 0.00
[pre]yes, I work with two cameras. You can change the names like this in Ascom and then you can see the difference[/pre]
tkottary 0.00
This works fine. In the nightly version of NINA, you can name the device .So it gets easier to choose
Florin77 0.00
https://youtu.be/ZJpUrvcLG-k?si=0UJhghTTnsCT36ST
WS65 0.90
thank you both … this is what I wanted to hear smile
