Canon 6D Images Autorotated Stefan Berg Nighttime Imaging 'N' Astronomy (N.I.N.A. / NINA) · Michele Bergo · ... · 6 · 130 · 0
astromichdundee 0.00
Hi all,
I'm using NINA controlling Canon 6D the images are correctly display in the image tab (width higher than height) but they are saved flipped by 90 degrees (height higher than width). Canon 6D autorotation option is disabled. has someone an idea of what is going on?
thank you in advance
Michele
pfile 3.10
what software are you using to open the files? are they in FITS format or are they CR2 files?
_Krzy 3.58
If I remember correctly, this is perfectly normal for some DSLR files, they're just read/written that way. All stacking software should handle this without an issue so it's purely cosmetic.
they are CR2 files and NINA is opening them
Mikolaj Wadowski:
ok I see but I have read the cr2 properties via exiftool and it is reporting:
Camera Orientation              : Rotate 270 CW
The autorotate in the camera is off
see log below
ExifTool Version Number         : 13.22
File Name                       : 2025-03-07_19-27-46__17c_60.00s_0000.cr2
Directory                       : C:/Users/Michele/Desktop/NINA/2025-03-07/LIGHT
File Size                       : 24 MB
File Modification Date/Time     : 2025:03:07 19:28:56+01:00
File Access Date/Time           : 2025:03:08 17:00:29+01:00
File Creation Date/Time         : 2025:03:07 19:28:56+01:00
File Permissions                : -rw-rw-rw-
File Type                       : CR2
File Type Extension             : cr2
MIME Type                       : image/x-canon-cr2
Exif Byte Order                 : Little-endian (Intel, II)
Image Width                     : 5472
Image Height                    : 3648
Bits Per Sample                 : 8 8 8
Compression                     : JPEG (old-style)
Make                            : Canon
Camera Model Name               : Canon EOS 6D
Preview Image Start             : 83648
Orientation                     : Horizontal (normal)
Preview Image Length            : 2290164
X Resolution                    : 72
Y Resolution                    : 72
Resolution Unit                 : inches
Modify Date                     : 2025:03:07 19:39:23
Artist                          :
Rating                          : 0
Copyright                       :
Exposure Time                   : 60.2
F Number                        : 16.0
Exposure Program                : Bulb
ISO                             : 1600
Sensitivity Type                : Recommended Exposure Index
Recommended Exposure Index      : 1600
Exif Version                    : 0230
Date/Time Original              : 2025:03:07 19:39:23
Create Date                     : 2025:03:07 19:39:23
Components Configuration        : Y, Cb, Cr, -
Shutter Speed Value             : 0
Aperture Value                  : 16.0
Flash                           : Off, Did not fire
Focal Length                    : 140.0 mm
Macro Mode                      : Normal
Self Timer                      : Off
Quality                         : RAW
Canon Flash Mode                : Off
Continuous Drive                : Single
Focus Mode                      : Manual Focus (3)
Record Mode                     : CR2
Canon Image Size                : n/a
Easy Mode                       : Manual
Digital Zoom                    : None
Contrast                        : Normal
Saturation                      : Normal
Metering Mode                   : Spot
Focus Range                     : Not Known
Canon Exposure Mode             : Bulb
Lens Type                       : Canon EF 75-300mm f/4-5.6
Max Focal Length                : 300 mm
Min Focal Length                : 75 mm
Focal Units                     : 1/mm
Max Aperture                    : 4.8
Min Aperture                    : 36
Flash Activity                  : 0
Flash Bits                      : (none)
Zoom Source Width               : 0
Zoom Target Width               : 0
Manual Flash Output             : n/a
Color Tone                      : Normal
SRAW Quality                    : n/a
Auto ISO                        : 100
Base ISO                        : 1600
Measured EV                     : 0.25
Target Aperture                 : 16
Target Exposure Time            : 1
Exposure Compensation           : 0
White Balance                   : Fluorescent
Slow Shutter                    : None
Shot Number In Continuous Burst : 0
Optical Zoom Code               : n/a
Camera Temperature              : 17 C
Flash Guide Number              : 0
Flash Exposure Compensation     : 0
Auto Exposure Bracketing        : Off
AEB Bracket Value               : 0
Control Mode                    : Computer Remote Control
Measured EV 2                   : 0.875
Bulb Duration                   : 60.2
Camera Type                     : EOS High-end
ND Filter                       : n/a
Canon Image Type                : Canon EOS 6D
Canon Firmware Version          : Firmware Version 1.1.9
Focus Distance Upper            : 0 m
Focus Distance Lower            : 0 m
Firmware Version                :
File Index                      : 1
Directory Index                 : 25599
Contrast Standard               : 256
Sharpness Standard              : 0
Saturation Standard             : 768
Color Tone Standard             : 0
Contrast Portrait               : -1379995682
Sharpness Portrait              : 222
Saturation Portrait             : 512
Color Tone Portrait             : 0
Contrast Landscape              : -1379995682
Sharpness Landscape             : 222
Saturation Landscape            : 1024
Color Tone Landscape            : 0
Contrast Neutral                : -1379995682
Sharpness Neutral               : 222
Saturation Neutral              : 0
Color Tone Neutral              : 0
Contrast Faithful               : -1379995682
Sharpness Faithful              : 222
Saturation Faithful             : 0
Color Tone Faithful             : 0
Contrast Monochrome             : -1379995682
Sharpness Monochrome            : 222
Filter Effect Monochrome        : Unknown (0xffffffffadbeefde)
Toning Effect Monochrome        : Unknown (0xde)
Contrast Auto                   : 0
Sharpness Auto                  : 0
Saturation Auto                 : 768
Color Tone Auto                 : 0
Filter Effect Auto              : None
Toning Effect Auto              : Unknown (0xffffffffadbeef00)
Contrast User Def 1             : -1379995682
Sharpness User Def 1            : 222
Saturation User Def 1           : 768
Color Tone User Def 1           : 0
Filter Effect User Def 1        : None
Toning Effect User Def 1        : None
Contrast User Def 2             : 0
Sharpness User Def 2            : 0
Saturation User Def 2           : 768
Color Tone User Def 2           : 0
Filter Effect User Def 2        : None
Toning Effect User Def 2        : None
Contrast User Def 3             : 0
Sharpness User Def 3            : 0
Saturation User Def 3           : 768
Color Tone User Def 3           : 0
Filter Effect User Def 3        : None
Toning Effect User Def 3        : None
User Def 1 Picture Style        : Unknown (0)
User Def 2 Picture Style        : Unknown (0)
User Def 3 Picture Style        : Unknown (34560)
Canon Model ID                  : EOS 6D
Thumbnail Image Valid Area      : 0 159 7 112
AF Area Mode                    : Off (Manual Focus)
Num AF Points                   : 11
Valid AF Points                 : 11
Canon Image Width               : 5472
Canon Image Height              : 3648
AF Image Width                  : 5472
AF Image Height                 : 3648
AF Area Widths                  : 82 82 82 82 98 120 98 82 82 82 82
AF Area Heights                 : 98 98 98 98 76 127 76 98 98 98 98
AF Area X Positions             : -1143 -547 -547 -547 0 0 0 547 547 547 1143
AF Area Y Positions             : 0 350 0 -350 488 0 -488 350 0 -350 0
AF Points In Focus              : (none)
AF Points Selected              : 10
Time Zone                       : +00:00
Time Zone City                  : London
Daylight Savings                : Off
Bracket Mode                    : Off
Bracket Value                   : 0
Bracket Shot Number             : 0
Raw Jpg Size                    : Large
WB Bracket Mode                 : Off
WB Bracket Value AB             : 0
WB Bracket Value GM             : 0
Live View Shooting              : Off
Shutter Mode                    : Mechanical
Flash Exposure Lock             : Off
Anti Flicker                    : Off
Internal Serial Number          : GD1175955
Dust Removal Data               : (Binary data 1024 bytes, use -b option to extract)
Crop Left Margin                : 0
Crop Right Margin               : 0
Crop Top Margin                 : 0
Crop Bottom Margin              : 0
Exposure Level Increments       : 1/3 Stop
ISO Speed Increments            : 1/3 Stop
AEB Auto Cancel                 : On
AEB Sequence                    : 0,-,+
AEB Shot Count                  : 3 shots
Safety Shift                    : Disable
AI Servo Tracking Sensitivity   : Fast
Acceleration Tracking           : 0
AI Servo First Image Priority   : Equal priority
AI Servo Second Image Priority  : Equal priority
AF Assist Beam                  : Emits
Lens Drive No AF                : Focus search on
Orientation Linked AF Point     : Same for vertical and horizontal
Superimposed Display            : On
AF Microadjustment              : Disable; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0
Dial Direction Tv Av            : Normal
Focusing Screen                 : Eg-A II
Multi Function Lock             : Off; Quick control dial
Viewfinder Warnings             : Monochrome, WB corrected
Custom Controls                 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Aspect Ratio                    : 3:2
Cropped Image Width             : 5472
Cropped Image Height            : 3648
Cropped Image Left              : 0
Cropped Image Top               : 0
Tone Curve                      : Standard
Sharpness                       : 3
Sharpness Frequency             : n/a
Sensor Red Level                : 0
Sensor Blue Level               : 0
White Balance Red               : 0
White Balance Blue              : 0
Color Temperature               : 5200
Picture Style                   : Auto
Digital Gain                    : 0
WB Shift AB                     : 0
WB Shift GM                     : 0
Measured RGGB                   : 539 1024 1024 601
VRD Offset                      : 0
Sensor Width                    : 5568
Sensor Height                   : 3708
Sensor Left Border              : 84
Sensor Top Border               : 50
Sensor Right Border             : 5555
Sensor Bottom Border            : 3697
Black Mask Left Border          : 0
Black Mask Top Border           : 0
Black Mask Right Border         : 0
Black Mask Bottom Border        : 0
Color Data Version              : 10 (1DX/5DmkIII/6D/70D/100D/650D/700D/M/M2)
WB RGGB Levels As Shot          : 1774 1024 1024 2450
Color Temp As Shot              : 3706
WB RGGB Levels Auto             : 1975 1024 1024 1762
Color Temp Auto                 : 5004
WB RGGB Levels Measured         : 1975 1024 1024 1762
Color Temp Measured             : 5004
WB RGGB Levels Daylight         : 2036 1024 1024 1730
Color Temp Daylight             : 5200
WB RGGB Levels Shade            : 2335 1024 1024 1456
Color Temp Shade                : 7000
WB RGGB Levels Cloudy           : 2194 1024 1024 1586
Color Temp Cloudy               : 6000
WB RGGB Levels Tungsten         : 1460 1024 1024 2583
Color Temp Tungsten             : 3200
WB RGGB Levels Fluorescent      : 1774 1024 1024 2450
Color Temp Fluorescent          : 3720
WB RGGB Levels Kelvin           : 2036 1024 1024 1730
Color Temp Kelvin               : 5200
WB RGGB Levels Flash            : 2255 1024 1024 1547
Color Temp Flash                : 6345
Average Black Level             : 2048 2048 2048 2048
Raw Measured RGGB               : 87502 161683 159448 92607
Per Channel Black Level         : 2047 2047 2048 2048
Normal White Level              : 11995
Specular White Level            : 12507
Linearity Upper Margin          : 10000
Picture Style User Def          : Auto; Auto; Auto
Picture Style PC                : None; None; None
Custom Picture Style File Name  :
AF Micro Adj Mode               : Disable
AF Micro Adj Value              : 0
Vignetting Corr Version         : 0
Peripheral Lighting             : Off
Distortion Correction           : Off
Chromatic Aberration Corr       : Off
Peripheral Lighting Value       : 0
Distortion Correction Value     : 0
Original Image Width            : 5472
Original Image Height           : 3648
Peripheral Lighting Setting     : Off
Chromatic Aberration Setting    : Off
Peripheral Illumination Corr    : Off
Auto Lighting Optimizer         : Off
Highlight Tone Priority         : Off
Long Exposure Noise Reduction   : Off
High ISO Noise Reduction        : Off
Ambience Selection              : Standard
Multi Exposure                  : Off
Multi Exposure Control          : Additive
Multi Exposure Shots            : 0
HDR                             : Off
HDR Effect                      : Natural
User Comment                    :
Sub Sec Time                    : 68
Sub Sec Time Original           : 68
Sub Sec Time Digitized          : 68
Flashpix Version                : 0100
Color Space                     : sRGB
Exif Image Width                : 5472
Exif Image Height               : 3648
Interoperability Index          : R98 - DCF basic file (sRGB)
Interoperability Version        : 0100
Focal Plane X Resolution        : 3810.584958
Focal Plane Y Resolution        : 3815.899582
Focal Plane Resolution Unit     : inches
Custom Rendered                 : Normal
Exposure Mode                   : Auto
Scene Capture Type              : Standard
Owner Name                      : filippo bolgan
Serial Number                   : 363051000615
Lens Info                       : 75-300mm f/0
Lens Model                      : EF75-300mm f/4-5.6
Lens Serial Number              : 0000000000
GPS Version ID                  : 2.3.0.0
Thumbnail Offset                : 80068
Thumbnail Length                : 3577
Photometric Interpretation      : RGB
Samples Per Pixel               : 3
Rows Per Strip                  : 309
Planar Configuration            : Chunky
Strip Offsets                   : 3234068
Strip Byte Counts               : 21079177
CR2 CFA Pattern                 : [Red,Green][Green,Blue]
Raw Image Segmentation          : 1 2784 2784
SRaw Type                       : 1
Drive Mode                      : Single-frame Shooting
File Number                     : 25599-0001
Lens                            : 75.0 - 300.0 mm
Shooting Mode                   : Bulb
WB RGGB Levels                  : 1774 1024 1024 2450
Aperture                        : 16.0
Blue Balance                    : 2.392578
Image Size                      : 5472x3648
Lens ID                         : Canon EF 75-300mm f/4-5.6
Megapixels                      : 20.0
Preview Image                   : (Binary data 2290164 bytes, use -b option to extract)
Red Balance                     : 1.732422
Scale Factor To 35 mm Equivalent: 1.0
Shutter Speed                   : 60.2
Create Date                     : 2025:03:07 19:39:23.68
Date/Time Original              : 2025:03:07 19:39:23.68
Modify Date                     : 2025:03:07 19:39:23.68
Thumbnail Image                 : (Binary data 3577 bytes, use -b option to extract)
Lens                            : 75.0 - 300.0 mm (35 mm equivalent: 74.1 - 296.2 mm)
Circle Of Confusion             : 0.030 mm
Depth Of Field                  : inf (0.00 m - inf)
Field Of View                   : 14.8 deg
Focal Length                    : 140.0 mm (35 mm equivalent: 138.2 mm)
Hyperfocal Distance             : 40.26 m
Light Value                     : -1.9
-- press ENTER --
It's a non-issue.
pfile 3.10
it is a non issue, i agree, because any proper astronomical image processing software will ignore that metadata when it opens the file.
but it is a little strange. i've never used NINA with a DSLR so i'm not sure if it is supposed to turn off that setting in the camera. is the orientation control turned off on the back-of-camera menu?
