My HEQ5 Pro was bought for me by me wife as a present 4 years ago. I guess it may have been manufactured a couple of years prior to that. I've noticed that it is quite "sticky" in both DEC and RA. I do get sub 1 arc secs guiding, but stars are still a bit affected. Apart from a Rowan belt upgrade and backlash tuning I have done nothing to it. I am now considering replacing all the bearings and cleaning up/re-greasing the worm gears. The bearings will only cost me about £60 plus the cost of a bit of superlube. Would you do it? I'm thinking it's a good investment and significantly cheaper than upgrading to a CEM70 or EQ6R Pro. |
Hi Andy, What do you mean by "stars are still a bit affected"? Personally, I would leave the mount as it is if it does a good sub arcsec guiding. Depending on what "sticky" specifically means in your mount's case, a bit of "stickyness" can be better than a completely frictionless bearing. Björn |
Björn Arnold: If I disengage the clutches, it takes some force to move the mount. It feels "gummed up" and not smooth; even without the OTA on it. I would say it feels like the grease is old and claggy (like a 1950's manual lense that I've been using on my mirrorless camera recently). |
I‘d do a partial hypertune, what is definitely a good thing is to replace the small bearings that hold the worm-gears. Mine were of horrible quality, you could feel that something was wrong with them. Easiest way to test is to either remove the gear in the middle or, if you already have belts, then remove the belts and manually turn the wormdrive gear of ra + Dec. My RA ran fine, but on Dec I could clearly feel when turning that things were not smooth. Turning the gears manually is also in my point of view the best way to later adjust the distance between the worm and the gear, it is easy to feel when turning if you are too tight or just right. It is also easy to replace the V shaped bearings in RA and DEC. Replacing the big bearings can be painful, I only replaced two of them and I saw in several hypertune reports that they are the least important to replace. The stiffness can also be caused by the mount´s bearings beeing tightened up too much, Check Astrobabies Page https://www.astro-baby.com/astrobaby/ there is more information on that in the Tuning section for the HEQ-5 Overall, the Hypertune did not make as much difference as the belt mod for me, but my mount was fairly new, so besides the wormgear bearings there was no real issue but in the process the stiffness of the axes went away so it is now a lot easier to balance the mount. Michael |
Hey Andy, Please update us with what you do! I also have a belt modded HEQ5 and your description of the "gummed up" bearings is spot on! My mount also feels sticky and I've heard that the lube they use from the factory is not exactly the best quality. I'm in the same mindset as you, trying to get some more mileage out of my HEQ5 before I inevitably upgrade to something bigger. Clear skies! |
Please update us with what you do I will do ... bearings and lube have been ordered and should arrive within 4 days. I'll post the results as soon as I can |
Hello, I have equipped my HEQ5 Pro with new bearings and better lube. After that, both RA and DEC were less smooth than before. I have not yet tested whether the tracking behavior is better than before the modification because I am currently using a different mount. I just wanted to say that the mount doesn't necessarily "run smoother" after replacing the bearings. Best regards, Markus |
OK, DEC axis stripped down, cleaned and re-lubed. Small bearings on worm gear were not good, however all the others seemed fine. Main bearings arrive 2moro, so will get the DEC and RA axes done then. FWIW: It's a fairly straightforward process so far. It's a really cheap upgrade to replace all the bearings and I can't see how it would make it any worse ![]() |
I had it from a very reliable source that bearings quality isn't that important past a minimum threshold. IOW, if they feel fine don't touch 'em. I do however sympathize with the urge to replace things old with new and the satisfaction that comes from putting everything back together. Good luck!
I had it from a very reliable source that bearings quality isn't that important past a minimum threshold. IOW, if they feel fine don't touch 'em. I do however sympathize with the urge to replace things old with new and the satisfaction that comes from putting everything back together. Good luck! The other really satisfying thing is getting to know your mount and how it works. They are actually very simple mechanisms (a couple of motors, two worm gears, a bunch of bearings and a control board) that could do with regular maintenance to keep them at their best. It's a lot simpler than my 3D printer. Although I'm replacing all the bearings with better ones because the total cost is only about £70, I actually think that the only ones that needed replacing were the little ones on the worm carriers ... total cost for those was £20 for four of them. |
OK, here's where I'm at right now: I managed to replace all but one of my bearings. One of the main ones was so stuck on the DEC shaft that I had no way of removing it. I found one of the bolts on the RA worm gear carrier had been cross-threaded during the manufacturing process, so I've removed it and am relying on just two to hold the carrier; I think that will be fine. There are two worm gear float adjusters that people have said to leave loose. I found that that left me with backlash in the RA, so they do need to be tightened up just enough to stop the worm moving from side to side. I need some clear skies now to see how well the upgrade has gone, but so far, so good. The one thing I can confirm is that the whole setup is much easier to balance after the upgrade. It's much smoother and more sensitive to slight changes in the position of the OTA and counterbalances. |
Andy Wray: Maybe is too late for this but, unless you have a bearing extractor, the way to handle this issue is to put the casing on the gas hob (or use one of those hot air guns) to heat it up and while (very!) hot hammer out the bearing. The difference in thermal expansion coefficient between steel and alumnium is large enough for this to work even at moderate temperatures (say 200 degC). |
andrea tasselli:Andy Wray: Unfortunately I didn't have that option based on where it was. That said, the main bearings on both the DEC and RA axes looked in pretty pristine condition when I removed them despite their age. I actually think that with the HEQ5 it is all about the worm gears, their bearings, their float adjusters and also the amount of pressure placed on the taper roller bearings on each axis. |
OK: the good news is that I don't appear to have broken my mount by replacing all the bearings. I've got it imaging tonight and it seems to be guiding slightly better than before the upgrade. Currently at 0.6 arc secs guiding RMS average. That's not much of an improvement, however two things seem to have improved: 1) The DEC and RA are about the same now which should give me rounder stars 2) The number of corrections being sent to the mount are far fewer 3) When I look at the PHD2 scatter diagram it is much rounder than before Fingers crossed, this was worth it. ![]() |
Hi Andy, Can you post a PE graphs of the before and after? That would be instructive… |
andrea tasselli: That would be great. I also use an HEQ5 and upgraded with the Rowan kit and adjusted the worms. The astrobaby link that Mike suggested in an earlier post greatly reduced my DEC friction. My overall total rms error is at worst about 0.8 arcsec/px. I also get higher RA error than DEC especially when imaging near the CE, but the RA and DEC error are close when imaging more northern targets with an overall total rms error around 0.4-0.5. Thanks for sharing this Andy. Just relaying my experience. Jim |
andrea tasselli: I will do once I have a longer test ... this was just a 35 minute guiding test and I didn't really polar align that well, but was a very clear improvement on before. I was going to do a longer test tonight, but despite weather forecasts the sky is full of clouds ![]() |
OK, the clouds cleared for a bit so I am imaging tonight. After 1.5 hours my guiding is as follows: * Total RMS is varying betwen 0.63 and 0.72 arc secs * DEC and RA values are between 0.42 and 0.5 arc secs * DEC and RA values are broadly equal at any one time which means round stars throughout Graphs will follow. N.B. I'm running an 8" Newtonian + camera, filter wheels, guiding cam, coma corrector, autofocusser etc. weighing 11KG in total on the HEQ5 Pro. I'm probably at the HEQ5 Pro limit for imaging to be honest. I will tune PHD2 some more and can hopefully get to 0.55 arc secs, but I can't see it getting any lower than that. |
Lots of whispy clouds tonight and yet guiding was at 0.64 arc secs RMS overall. It looks like we may have clear skies in a couple of days, so will be good to see how it performs then.
Beautiful guiding results Andy! Thanks for the graph too. if you don’t mind me asking, what was your target? Thanks, Jim |
Beautiful guiding results Andy! In this case it was M51 if that is what you meant by target. If you meant what target RMS guiding I was aiming for then it was 0.55 arc secs which I do achieve now when the sky is as crystal clear as it can get in my suburban area. I think I could improve things by focussing my OAG better, tuning out any residual backlash and tweaking PHD2 settings, however that can wait for now as it's "good enough" and the skies are clear so I just want to be imaging right now. |
Andy Wray:Beautiful guiding results Andy! Thank you Andy. Yes, I was talking about the target that you were imaging. 0.55 total rms guiding error in arcsec is really good. There are lots of folks with much more expensive mounts that would be very pleased with numbers like that. My HEQ5 is about a year old and after the belt mod and tuning the backlash, it performs similar to yours. I will keep in mind the bearing replacement that you performed as I plan to keep this mount for a long time (I'm not young) if not much of my imaging career. I peered back in the posts above and I don't see exactly what bearings you replaced. Would you mind listing their part#'s. Glad to hear things worked out so well. Enjoy your night of imaging! Jim |
Andy Wray:Would you mind listing their part#'s. Thank you Andy! |
