Samyang 135mm f/2.0 – Sensor Tilt or Another Bad Copy? Samyang 135mm F2.0 ED UMC · Michael E. · ... · 54 · 1899 · 11
mex 0.00
Mohammed Khalifa:
Michael E.:
But at 2.8 the aperature is 48mm. Compared to being wide open, you are going to need to double your exposure time for a similar image. It might be worth considering taking a few frames to do a star overlay at 2.8 but the bulk of your imaging session at 2.0 would be the best bang for your buck.
Thanks for your advice. You’re correct that at F/2.8, it would require doubling the total integration time to be comparable to F/2.0.
If I understand you correctly, you're suggesting using the stars from the F/2.8 integration and the starless image from F/2.0. The point is that BXT has no problem correcting the star shapes per se, but rather struggles with filling the gaps in the starless image. So, I’m afraid this approach won’t help much, especially when there is a lot of nebula present.
There is a cropped image shot at F/2.2 illustrating this effect further up. Maybe someone has an idea on how to mitigate this effect other than just dialing the stretch down? Usually my worflow starts with SPCC followed by BXT and SXT (all in lienar state)
So I faced something almost similar but not black gaps, after applying BlurX, big stars left a huge ring around them. So what I did is apply StarX first then apply BlurX on the stars image alone, and the starless alone and it worked.
So you can try this, StarX before BlurX, then apply BlurX two times on stars and the starless.
I know this is not how it should be done, but it worked for my case.
So your procedure actually worked pretty well, and I don't really notice any difference in the starless structures when BXT is being applied on the starless image - although to be fair, there is not much structure here...
See for yourself:
I also noticed that when applying the star halos adjustment, the effect was slightly less pronounced but never as effective as with your method.
Michael E.:
Download link would be ideal.
I just realized that the samples I provided were processed on drizzled data, where the effect is much more pronounced.
If you'd still like to give it a try, here is a download-link to a significantly cropped (for file-size reasons) raw stack of the drizzled data:
https://www.swisstransfer.com/d/926cfb25-1411-487d-9197-10bbf2e2fbb6
As I said, none of those issues (dark halos) appears (and no need for any gimmick here, right straight off the bat):
I also noticed you stepped down the lens, isn't it?
On a second view I noticed some minor artefacts which are undoubtedly due to the drizzling process (when the random drifting for an OSC isn't good enough), which sometimes I experience myself (in the very rare event of me drizzling 2x anything). On the plus side you got a minor planet  passing by in the picture smile. With a large enough amount of exposures and some random scattering the issue should go away in the final processed image.
mhk.astro 1.20
Michael E.:
Mohammed Khalifa:
Michael E.:
See for yourself:
Glad it helped! I heard that RC is going to update BXT and SXT soon in Adam Block’s recent video with him, lets hope it will resolve those issues that were introduced here.
mex 0.00
On a second view I noticed some minor artefacts which are undoubtedly due to the drizzling process (when the random drifting for an OSC isn't good enough), which sometimes I experience myself (in the very rare event of me drizzling 2x anything). On the plus side you got a minor planet  passing by in the picture . With a large enough amount of exposures and some random scattering the issue should go away in the final processed image.
Thanks for your attempt. Yes, the artifacts become of course more visible when stretching the image like Superman :-)
It's correct (and also a bit misleading in this topic) that I stopped it down. But it was just one click to F2.4 (I assume, because it's unlabeled), where there was no positive effect yet on the star shapes, with my copy at least. At F2.8 though, things start to get much better.
Ah, now I see what you mean by the "planet thing" — it's that little stripe! :o
Judging by the shape of that asteroid (or whaever it might be), I must have regularly thrown out some data in between because it looks like only a few subs were used. In fact, the stack consists of more than 1000 x 20" exposures, although taken during pretty bad conditions.
