Questions about autofocus with the Rokinon/Samyang 135mm f/2.0 ED UMC Rokinon 135mm f/2.0 ED UMC · Alan Brunelle · ... · 26 · 1319 · 0
JohnNoble 3.31
Alan,
Thanks again for the reply.
I don't use Nina I just use the ASI Air so I don't have as much flexibility with the focus routine as you might in Nina. Anyway your suggestion to check the log was is great idea. I'll have to go out to the scope for that but I did check one I had from a successful run with another scope and it confirms the cycle I noted above. Will be interesting to see what the failed run with the 135 mm shows!
Thanks again
Alan_Brunelle
John, best of luck.  Maybe an ASIAIR expert will weigh in.
