QHY600 Background noise QHYCCD QHY600PH M · sjunge · ... · 12 · 586 · 1
sjunge 0.00
Hello together,
I have the impression that my QHY600M has problems with background noise and I am in discussion with my dealer. The camera is second hand and was at the dealer for repair a week ago. After testing it, I notice a background noise even at lower temperatures that I have never seen before. The dealer insists that the noise profile is normal, but I have concerns. The profile shows noise as high as 50k ADU at 0C and 240s. Also at -10C the noise is remarkable hight. Bias images look normal and as expected.
Could someone be kind enough to provide me with some sample images for bias and dark and a uncalibrated light 1x1 and 2x2 for comparison? That would be great.
Thanks
Sven
JohntheLast 0.00
Any particular gain? I've got 1x1 but not 2x2.
Xtasqf 0.00
Hi Sven
I was also very surprised at the beginning when I started using the QHY600 !
This phenomena is known with that cam and it can be corrected 100% with cosmetic correction during integration in Pixinsight
If you choose carefully your meds, gain and offset according to the QHYCCD documentation you can have very good results
Philippe
MarkUS_UK_Astro 0.00
I also see lots of warm pixels and had a noisy bias. Cosmetic correction and dithering clears the impact of the warm pixels and finding the right USB traffic setting fixed the bias noise issue. Both things were a major concern initially - but now dealt with.
morefield 12.31
Sven,
Could you post a link to one of your bias or dark subs?
Thanks,
Kevin
PABresler 0.00
You might contact QHY support [email][email protected][/email]
He also will want a dark frame. Use Dropbox.
Peter
jhayes_tucson 26.84
Hello together,
Thanks
Sven
I've been through the wringer with QHY600M background noise but I can't tell what you have going on from your description.  Can you post a histogram of a light frame taken of a dark region of the sky?  The histogram should show a very tight peak at the low values and you should see stars in the image.  I've had a failed camera produce a "grey" image showing few stars and instead of a nice sharp peak for the background, it showed a large distribution of values in the histogram--up to 50k ADU.  If that's what you are seeing, that camera probably has a problem.  Posting a link to a light and a dark for your camera would be very helpful as well.
PABresler 0.00
QHY provides good service but it probably means a 2 to 3 month trip to China. One of my 600s is there now because cooling failed.
Peter
PABresler 0.00
If the camera is under warranty with no signs of use they will provide a refurb from Santa Barbara, Ca.
sjunge 0.00
Hallo,
thanks for your replies. I have uploaded the bias, darks and 2 lights (crops) to my dropbox. Also a snapshot of the histograms. Compared to a QHY268, the noise seems to be much stronger with the QHY600.
In the past I have used an ATIK 16200 and the results, especially the uncalibrated images, are much better than with this camera. This really worries me.
Sven
Dropbox-Link:
https://www.dropbox.com/scl/fo/ne3ql09gw2hc1s252fro0/h?rlkey=wnohv9n48bue5facdsn95gve0&dl=0
sjunge 0.00
John Sikora:
Dear John,
I did the first evaluarion w. DSO16 gain 26 offset 30 in 1x1. But also other readout modes and gains could be helpfull as reference. Because of the high night tempearture the lowes temperature I can gain are -15C.
Thanks
Sven
jhayes_tucson 26.84
John Sikora:
Dear John,
Thanks
Sven
Sven,
Thanks for doing that!  My first reaction is that what you are seeing is not what I saw when my camera failed.  When I get a little time this afternoon, I’ll upload some good dark files and see if I can find the histograms showing what my camera looked like when it failed.   I’ll also try to take a look at your data to see how it compares.  I’m pretty busy today but I’ll do my best to get back to you ASAP…
sjunge 0.00
Hi together,
Can any of you provide some darks and bias? That would be very nice and helpful.
Any kind of gain/offset at 10C 1x1 is welcome.
Thanks
Sven
