PixInsight 1.9 frequent crashes on MacOS Pleiades Astrophoto PixInsight · Johannes Maximilian Möslein · ... · 53 · 2778 · 0
Joo_Astro 3.80
Unfortunately, it seems like PixInsight is unusable on MacOS after 1.9 Lockhart.
I experience frequent crashes (<5 mins) during processes, editing and scripts. Many of them are reproducible 100%. Sometimes it crashes even while doing nothing at all.
I tested on 2 different Macs, both up to date and with zero problems with 1.8.x.
Looking through CN and PI Forums, it seems like many others are having the same problems.
Hopefully we will get fixes soon, but until then, I will have to go back to 1.8.9.
Johannes
Roy-Hagen 10.66
Johannes Maximilian Möslein:
Johannes
I experienced the same problems after upgrading to 1.9.1
I ended up downgrading to 1.8.9
wsg 11.51
No problem at all with 1.91 here.  M1 Max, Sequioa 15.2.    Although they rushed Lockhart out for some reason,1.91 is working fine for me.
pfile 3.10
there is a little bit of hope - they have tagged a couple of bug reports in the PI forum, one as confirmed and one as under investigation.
tboyd1802 3.34
Haven't upgraded to 1.9.1 yet. But, I did upgrade to 1.9 and used it  bit, experienced no problems. In fact, the upgrade seems to have fixed a problem I experienced, but they could reproduce on 1.8.9 which was the inability to activate closed windows and process icons by selecting them. I'm running on an M1 Mac mini running Sequoia…
azskyguy 0.00
It’s a holy mess for me. Crashes with FBPP and WBPP.
GeorgeM 0.00
Johannes
same here and even the updated version crashed and  I lost my toolbox in script menu along with Graxpert etc. I have now removed it and gone back to 1.8.9 for now
George
rodolgo-outlook 0.90
Had trouble like many others with 1.9, updated to 1.9.1 and no issues (so far…).
M2 Max, MBP, 64 GB Ram.
Apparently, the QT framework is playing bad tricks on Sequoia.
mgermani 5.38
I haven't updated to 1.9.1 but I'm running 1.9 on Mac OSX 15, Mac Mini M4 Pro, no issues yet, but I haven't stacked with it (I use APP for stacking). Scripts, processes seem fine so far.
Teo_ 0.90
No issues on M1 Max with 32 GB of unified memory with MacOS 15.2 and PixInsight 1.9.0.
Bennich 5.02
I have processed an image, but not yet done any stacking on 1.9.1.
So far no issued on Macbook Pro M2 Max.
Have also tried FastDrizzle which worked for me as well.
Waiting for NSG to be updated to the latest release before stacking anything as that’s my preferred tool for normalization.
GeorgeM 0.00
The first time my Mac crashed after the newest update 1.9 Lockhart was during stacking.
George
backhaus 0.00
I feel you - went back to 1.8.9 myself. Trying to run Image Solver alone kills 1.9 & 1.9.1 on MacOS 14.7.2 here (almost) every time. So does WBPP.
jrlpereira 0.00
1.9.1 seems to be working fine on m4 max, no issues so far
EsaViitala 1.20
Cannot get WBPP to execute. It (1.9.x) crashes when arriving Registration. Plate solving crashes every  time.
But 1.8.9 runs well with the same data set. Mine is an Intel based Mac, running the latest MacOS.
surfinash 1.51
Has happened to me as well. Lost a lot of time (I have an M2 Mac). I downgraded to 1.8.x
lstjpn 0.00
I had it crashing all the time on 1.9, the upgrade to 1.9.1 solved all the problems I was having.   Running on an M1, and M2Ultra and an M3Pro, it was the same across all three systems.
NorskeDude 2.33
1.9.1 Crashed with Image Solver. Reloaded PixInsight, was able to run Image Solver. Even with the astronomical solution, AstroBin doesn't recognize it & plate solve failed on my recent image.
MacBook Pro M3Max 64Gb
WaldiWaldemar 0.00
1.9.0 and 1.9.1 working fine on my mac mini m2 (Sequoia 15.2) ,image solver, image processing, scripts works.
I can't say anything about stacking, I use APP
The_lazy_Astronomer 1.20
for now , it is working well on mac book pro M4 on sequoia as well .
alfredobeltran 0.90
No issue at all so far with 1.9.1 running on a M1 MacBook Air.
Drizzle integration was so much faster than before and processing was as smooth as 1.8.9
rafaelss123 1.20
Ricardo Pereira:
No issues with my M1 Max so far.
Thinking about upgrading to M4 Max. Are you having the performance you expected?
GreatNeckObservatory 0.00
Thanks for this thread.  Looks like I will wait a little longer for them to get the bugs out.  Clear skies
Mark
Bennich 5.02
Seems like the PixInsight team has confirmed bugs related to above - https://pixinsight.com/forum/index.php?forums/bug-reports.6/
Joo_Astro 3.80
Just a quick update from my side:
I tried installing 1.9.1 again, and it seems like the unprovoked crashes have stopped for now. Also, the bugs with the trackpad lagging and randomly scrolling are gone.
But the reproducible crashes (like ImageSolver with Distortion Correction checked, or during WBPP) still exist.
Johannes
