How can I get WBPP/FBPP to write to a locally-attached NAS? Pleiades Astrophoto PixInsight · Peter Goodhew · ... · 7 · 273 · 0
PeterGoodhew 4.73
How can WBPP/FBPP read files from a locally-attached NAS (network storage device) but can't write back to it?
Error message is:
File I/O Error: Unable to create directory: Win32 error (161): The specified path is invalid.
Marcelof 6.20
At the moment it is not possible. PI does not like NAS or online synchronized backup disks, as you have seen, if you try to do it, a series of errors appear.
PI likes local disks, no matter if they are internal or external.
Old-Photons 0.00
I do not use this, but I believe that if you Map your NAS as a drive it will work.  Here is how to do that: https://www.solveyourtech.com/windows-11-how-to-map-a-network-drive-a-step-by-step-guide/
Alexn 12.25
You could certainly map the NAS as a network drive…
Let me play devils advocate and ask you…  WHY?
I don't care how good your network is, from a performance perspective, running WBPP to a NAS would SUCK from a performance perspective…
You'd be much better to set up a schedule task or a script that mirrors data from a local disk where you perform WBPP, to the NAS… And ultimately, clearing the directory on the local disk too…
Its not even that PI prefers local disks, its that read/write speed is SUPER important in WBPP… That's half the reason why FBPP was created - to reduce the IO bottleneck by keeping everything in memory.
A really good, low latency/high efficiency NAS will have something around 110MB/sec. A USB SSD will double that for performance to around 200MB/sec. a local spinning disk will double that and then some again at 550MB/sec, and a top tier NVMe SSD might be as high as 15,000MB/s.
I would honestly avoid using NAS for WBPP at all costs if I were you.
GiffS 5.49
I messed with this and Alex is 100% correct. Trying to run WBPP on a NAS is frustrating at best and disastrous at worst. There is no upside. PI won’t even run well on a drive that syncs to a NAS in my experience. I use my NAS as my long term repository of lights and masters.
Alexn 12.25
The big risk you run with any DFS/RFS (Distributed/Replicating File System) is data corruption if things get touched/updated while a replication is occuring, but yes, if your sync to the NAS is done by 'watching' the target file system, then triggering a sync with the NAS when things are changed (essentially, a live, differential backup) that will incur a fairly heavy performance hit.
What I was suggesting was having a local 'working' directory on the machine, then having a scheduled task that backs up that directory/disk (or even better, things that changed) at say, 4am.
I would never recommend any process of cloning files while they are in use as the performance hit is significant, and the risk of corruption is absolutely an issue to be considered as well.
GiffS 5.49
In a perfect world, one where I knew what the heck I am doing computer-wise, I would create a working folder on my local drive for a specific project where I would put my lights and calibration files and my WBPP outputs. That part I got no problem.  Then I would set up a schedule on my NAS that would copy only the lights and master folders to the appropriate location in my data archive directory on the NAS and delete unwanted folders. That part is something I aspire towards, but I am not there yet so for me it is a manual move later then I delete the unwanted folders and reclaim the space on my local.
KGoodwin 4.71
You really want to do all your PI stuff on a local fast disk, which can be pretty small, and then move everything off to the NAS once you're done with a project for long-term storage.  You can also store all the raw stuff from the camera on the NAS until you're ready to work on it.
