Help with WBPP "no frames found after calibration" Pleiades Astrophoto PixInsight · Oscar · ... · 2 · 150 · 4
I'm getting this, and I'm unable to stack
these are my lights:
(600s lights are named "Venus", but that's incorrect, just something that the ASIair does when you slew from a named target to an empty piece of sky - the name for the captured subs don't change after slewing from the named target; I guess the AA should've named it FOV, but I don't think this will affect stacking in any way.)
my flats:
this is what calibration shows:
I was trying to stack 300s lights with 600s lights, and I have all the correct flats per session, and the correct darks per exposure time, and biases
but it has a problem with my flats, "no frames found after calibration"
Never use WBPP.
wsg 11.51
There is a tab called Calibration Exposure Tolerance it should be set to "tolerate" both exposure times.  Yours is at 2, it should be 300.
Read more, post in the forum less.
