DNALinearFit scrip PixInsight, Pleiades Astrophoto PixInsight · Alonso Uribe · ... · 12 · 1210 · 1
Myriad_Astro 0.00
I am currently working on a 6 panel mosaic of M31
I have all the data I wanted, stacked and ready to begin the stitching.
I am following this tutotial https://www.youtube.com/watch?v=FkJKE-IWwTI&list=PLDNYZeyHBIFMGQ3-NWu9ek8C9yXuyA1ob&index=2
And panel #5 and 6, after running the DNALinearFit Scrip instead of the result being the image processed by the scrip I only get a black image with nothing on it.
All other 4 panels have no issues, after running the scrip I do get some image processed results.
After DNALinear, I do a GradientMergeMosaic as per the tutorial above, only panels 1 to 4 will stitch in the mosaic but not 5 and 6
Below you can see panel 6 result after running the DNA Scrip  (not good) Panel 4 shows a good result, and panel 5 has not run through the scrip yet
Any ideas/suggestions?
Die_Launische_Diva 11.54
I think today there are far better tools for mosaics. Search for MosaicByCoordinates or the tools from John Murphy (PhotometricMosaic and NormalizeScaleGradient). If I were you, I  wouldn't invest time on older workflows based on DNALinearFit.
John.Reed 0.00
I have had the best results with MosaicByCoordinates by John Murphy (PhotometricMosaic and NormalizeScaleGradient). There may still be some cosmetic issues. At the borders,  but it works better than anything I have tried.
Agreed 101% with Diva above.
olnilsa 0.00
I can recommend the PhotometricMosaic - works fine and gives no artefacts!
fjwidmann 0.90
I had good results on a nine-panel Andromeda image using NSG and MosaicByCoordinates/
tengwall 0.00
I would also highly recommend mosaic by coordinates. That had always worked well for me.
rwittich_de 0.90
I tried this workflow yesterday:·       Script/ImageAnalysis/ImageSolver for all Frames·       Script/Mosaic/MosaicByCoordinates·       GradientMergeMosaic
Thats all and it workes fine
Stephen.J 1.43
This clip is very easy to follow.  https://www.youtube.com/watch?v=pBX1pMkrlLY
Leon87 0.00
I just finished a 6 panel mosaic of the Sadr region. I recommend you the following workflow from Adam Block's Horizon:
-bxt
-mosaicbycoordinates
-trimmosaictiles
-photometric mosaic
The tesult is superb even with default values of each script.
Vlerma 0.00
Hola Alonso, yo sigo este vídeo con buenos resultados.   https://www.youtube.com/watch?v=xoE35tDwqKg
Myriad_Astro 0.00
Stephen Jones:
Thank you very much to all of you for your recommendations, following the video above gave me amazing results! I will make sure to try some of the other recommendations and maybe I can find a better simpler solution.
Myriad_Astro 0.00
VICENTE LOPEZ DE LERMA:
Muchas gracias Vicente!
Voy a darle una mirada a el video y de seguro lo intentare. Saludos cordiales!
