Yuxuan:
Ruediger:
Yuxuan: From anecdotal evidence I heard from a 12.5" CDK user in Louisiana (with high humidity), Pegasus UPB worked well for him in controlling dew while the native Delta T failed.
Easy to explain: UPB works with dew point, whereas the Delta-T either overheats or kicks in far too late. Any solution (or work around) using a humidity sensor is superior to the native solution. PWI3 lets DeltaT heat the primary backplate to a certain temperature above ambient, but it's not the backplate that dews... (insert facepalm emoji here)
On the AGO iDK, the control logic is to heat the (edge of the) primary mirror to a certain temperature above ambient. Even without measuring humidity the heater works well for me in humid Florida. MY AGO works fine, even if the logic of the control system is kinda rudimentary. It's better than this for sure.
To add some more details: EFA ambient sensor is here (credits: image from PWI)  The PWI 3.5 SW can be scripted since the web services can easily be accessed. But why should I write SW for a setup beyond 30 kEUR? I expect these things to work on purchase. Here an example Bill from PWI support mailed to me: ############ So now, for example, you can navigate to a URL like this: http://localhost:55555/?device=heater&index=0&mode=on&power=50to turn on the primary heater (index=0) and set it to 50% power. Or you could turn off the secondary heater (index=1) like this: http://localhost:55555/?device=heater&index=1&mode=offSimilarly, you can force the fans to be off like this: http://localhost:55555/?device=fans&mode=offAnd you can switch the fans back to their normally-configured operating mode like this: http://localhost:55555/?device=fans&mode=normal(This is basically equivalent to checking/unchecking the "Ignore Config and Set Fans Off" checkbox in the GUI.) ############
The fans I have a few different ways of working around. The secondary can use Delta T, but the primary has no trigger since that data is only accessible from EFA, which I don't have and really don't want to pay $1200 for.
Yuxuan:
Ruediger:
Easy to explain: UPB works with dew point, whereas the Delta-T either overheats or kicks in far too late. Any solution (or work around) using a humidity sensor is superior to the native solution. PWI3 lets DeltaT heat the primary backplate to a certain temperature above ambient, but it's not the backplate that dews... (insert facepalm emoji here). However this shortcoming seems to have been addressed in DWM, which allows one to keep the primary mirror temperature to a certain amount above ambient.
On the AGO iDK, the control logic is to heat the (edge of the) primary mirror to a certain temperature above ambient. Even without measuring humidity the heater works well for me in humid Florida. But the primary mirror temperature isn't known by DHM. So how is it keeping the primary mirror temperature to a certain amount above ambient? All DHM knows is ambient, humidity, and secondary mirror temp.
But the primary mirror temperature isn't known by DHM. So how is it keeping the primary mirror temperature to a certain amount above ambient? All DHM knows is ambient, humidity, and secondary mirror temp. That's why I have kept EFA and Delta. At the moment, there is no way round both units, if you want to keep reliably the mirrors dew free.
Ruediger:
That's why I have kept EFA and Delta. At the moment, there is no way round both units, if you want to keep reliably the mirrors dew free. Yup, I agree. The bottom line is EFA+DT+UPB+DHM+PWI does seem to work. That’s a lot of acronyms.
Ruediger:
Ruediger:
Yuxuan: About the series-5 controller, currently it only works with series-5 focuser/rotator on the Delta Rho, but PW has hinted to me that it may be adapted for CDK14 and up with Hedrick focusers. I think in order for them to come to their senses customer demand is key.
Right now they insist that the current EFA+DT combo works well for many of their scopes up to 1m ones deployed around the world. I doubt it in very humid climates, but I tend to agree with them for a setup in, for example, New Mexico. That’s what they had told me too - until I have proven by evidence that it cannot work under some conditions. After that they admitted they never tested it under less optimal conditions.
I gave up on that point. DHM works for me now, but the basic concept fails by design.
CS Rüdiger What is DHM? I saw this mentioned before, is this a new software solution that helps make Delta-T more useful?
After more than a year back and forth, PWI accepted that it does not work in my climate conditions and a lake of water in the tube. They have provided (as work around) an additional piece of software which can evaluate an ASCOM humidities sensor and controls fans and heaters based on the dew point instead of temperature only. This was never officially published, since „everything works so great“ 🤪
Only with DHM (Dew Heater Manager) I can run the CDK in my climate conditions, which is actually quite average. The link Rouz provided earlier has a download for Dew Heater Manager 1.0.0 and 1.0.1. I have downloaded them both.
Link: Index of /files/tools (planewave.com)
So, if I understand you correctly, this can use any ASCOM Observing Conditions driver to evaluate humidity data to make decisions about operating the heaters and fans? If so, how does it then tell the fans to run? I thought the EFA was needed to interface with the fans?
Does this run on its own or do you run with the other PWI3/4 software?
*It needs an ASCOM RH sensor and reading but the main issue is that it needs the primary temp provided by the EFA. With the Delta T you only get the backplate temp and the software didn't work for me. I spoke to PW and asked if they could change the software to use the backplate temp., they were not to happy that we are using his software as it wasn't meant to be public and more of Beta.
*I'd leave the fans on. The CDK14 doesn't have those side fans, I thought about adding them but Bill was saying it wont do much as the there is a deflector that forces the air over the primary. I noticed a 200 micron shift in focus everytime I turned the fans off. PW seem to believe the boundary layer but, I suspect its mechanical pressure under the mirror. The fans didn't work with PWM either.
Rouz Astro: I spoke to PW and asked if they could change the software to use the backplate temp., they were not to happy that we are using his software as it wasn't meant to be public and more of Beta. Hi Rouz, they are not happy we use DHM? Did I get that right? We would not need it, if they would not make such a bizarre concept. CS Rüdiger
Rouz Astro:
Ruediger:
Ruediger:
I spoke to PW and asked if they could change the software to use the backplate temp., they were not to happy that we are using his software as it wasn't meant to be public and more of Beta. So how have you been heating the primary mirror?
Yuxuan:
Willem Jan Drijfhout: I believe the Delta T can use 'backplate' temperature for that, a kind of proxy for ambient. Based on graphs that Ruediger published earlier, secondary seems highly variable, so not a good choice. Whichever temperature used (even with primary mirror measurements using EFA), none is ideal, as it does not take into account humidity and therefore dew point. That is where John Hayes's electronics comes into play to solve. Otherwise (and that is how I plan to use it for now) it is a matter of turning on at a fixed %, and experiment with what setting works generally well under you local conditions. It would be interesting to hear Rouz's latest experiences. I believe he even ran it (for a short while?) without a Delta-T at all, and just used UPB to control power to the heaters.
Yeah if I've learned anything here the solution @John Hayes designed is the best way to approach and solve this significant design flaw. I would be happy to pay for one, or build one from a set of instructions. 🙏
In lieu of that, I guess people without the EFA and only Delta T are using the backplate temp to trigger heating the primary for some random amount of time?
I just realized that I don't fully understand @John Hayes 's approach. Is the control logic the following?if TDPS<6C then
PassThrough (DeltaT)
else HeaterOff
If so, what is the ambient-secondary and ambient-backplate temperature difference set in the Delta T? Bill, That's the basic idea but it's implemented in a slightly more sophisticated way. If you were to simply implement the simple on/off logic that you listed, the controller could oscillate when the measured DeltaT is near 6C. Instead, my controller implements a "latched" switch. The heater is set to ON when DeltaT falls below the specified threshold (in this case 6C) and that event resets the value needed to turn the heater OFF. My latch value is 1C, which means that DeltaT has to go above 7C for the heater to turn off. My controller also includes a status monitor and command processor so that it's easy to manual control things if necessary. It checks for measurement mismatch between the two sensor to detect errors and the sensors are connectorized to make them easy to change in the field. At the moment, one of the sensors on my 20" controller has gone bad so I'm taking a bag full of them to store at the site to make replacement easy. I typically set the ambient-backplane temp difference in the DeltaT to 3C and that seems to work well. When I look at the data in the morning and see that the primary and secondary temps are a constant 3C above ambient, I know that the heaters were turned on. This worked well for a few month before I visited the observatory last February. There were water drop trails through the dust on the sides of the scope but the mirrors were perfectly clear. I'm heading out there again in another month so we see how it looks after more than a year. I'll send you an email about what I can do to help you out with your new scope. John
Ruediger:
Hi Rouz,
CS Rüdiger *Hi Ruediger, Well, first they asked where did I even get it from? Then they said that is not an official software and was just made at the request of someone (I believe you). When I asked can you switch from EFA temp to delta T temp. it seemed they didn't really have much interest to support much as PWI3 is what is meant to run the heaters not DHM. CS Rouz
Rouz Astro:
Ruediger:
Ruediger:
*Im heating the mirrors with deltaT without any regard for RH as I have no choice. I keep a slight increase like 0.8degC as I always need heating anyway in coastal Vancouver with high RH. Something I have noticed is that even though the scope is always outdoors in a plastic dome and very close to ambient, as the night temps drop the primary heater almost never turns on. The fans are always on and I have a 10inch fan sucking cool air into the dome and out the back. Ambient temps don't drop that fast here but the primary still doesn't catch up and is always warmer. The primary barely needs heat in my case, that may be the case for many others too. Its the secondary that is always modulating on/off at low power. When the my DeltaT was fried, the UBP can run the heaters too but its not a great solution as its blind even if you use the RH reading. Also a major flaw with a 3rd party heater like that is that it sends the same power to both the primary and secondary. Cs Rouz
Rouz Astro:
Ruediger:
Hi Rouz,
When I asked can you switch from EFA temp to delta T temp. it seemed they didn't really have much interest to support much as PWI3 is what is meant to ruin the heaters not DHM.
CS Rouz Hi Rouz, that is very strange, since Bill know from me that we are in touch - also for the dew problem. I told them, there are more users with the same issue. Here we have three CDK 14 all using DHM, because otherwise you don't get them work here. Moreover, basically the majority of CDK users know each other. So I wonder, why they are pissed off. That indicates to me that they are aware that they have an open point here. But then I wonder, why they put DHM on there file share for public access. That does not match. The request you have placed I asked also for. But with the same result. It looks like they are not interested to bring a solution for that issue, what look s very strange to me. Can you please help me with the your last sentence? I do not get what do you mean with "PWI3 is what is meant to ruin the heaters not DHM". Thanks! Rüdiger
John Hayes:
Yuxuan:
else HeaterOff
John *Thats interesting, I'm setting the heating to much lower, 0.8 to 1C over ambient. But its regardless of RH. RH is very high here, the fans being on and the slight heat seem to be keeping the dew under control. It got down to -11c last week but everything worked well. Like you, I'm also using backplate temp. I was thinking of pulling the mirror and thymically removing the backplate sensor and sticking it to the rear of the primary. I might do that at some point. Trying to swap the wires at the harness access panel in the back seems risky as it might fry something. CS Rouz
Ruediger:
Rouz Astro:
Ruediger:
Hi Rouz,
CS Rouz Hi Rouz,
Rüdiger *Hi Rudiger, Sorry that was a typo! "PWI3 is what is meant to RUN the heaters not DHM" - not ruin. They weren't pissed off, but as you said didn't seem interested in pursuing it further. asked for a simple edit to use the backplateT instead of the primaryT. This way, we don't need the EFA and the Delta T can run the DHM with any ASCOM RH sensor. CS Rouz
Ruediger: But then I wonder, why they put DHM on there file share for public access. That does not match. Indeed, makes one wonder if they put it there for some internal purpose and forgot it was there. Better grab it before it goes "poof"....  |
Bill McLaughlin:
Indeed, makes one wonder if they put it there for some internal purpose and forgot it was there. Better grab it before it goes "poof".... For sure. You never know when that will come in handy. This has got to be the most bizarre engineering decision and equally as bizarre response to customers on the matter. They really need to step forward and provide a real solution. They also need to edit their website to make it clear that Delta T requires EFA for some of the features they claim you get with just Delta T. The way the product is marketed now is incorrect, misleading, and is a consumer protection problem just waiting to happen.
In all fairness the DeltaT PWI3 combo has been working for me without the EFA despite freezing temps and very high RH.
Yes, dew point is missing from the equation.
I think the heat shedding rate of the primary is the key, at least these are not full thickness blocks of glass.
CS Rouz
I highly encourage every user who's not satisfied with the current solution write to PW and ask for an update. At some point I was told in principle series 5 control box can be adapted for CDKs including the CDK12.5, but the CDK12.5 adaptation is not currently under consideration because of lack of customer demand.
PW's customer service has been very responsive and helpful. But in my communication with them on this matter, I feel that their lack of motivation comes from a false sense that their current solution works extremely well and no competitor is even close.
Yuxuan: I highly encourage every user who's not satisfied with the current solution write to PW and ask for an update. At some point I was told in principle series 5 control box can be adapted for CDKs including the CDK12.5, but the CDK12.5 adaptation is not currently under consideration because of lack of customer demand.
PW's customer service has been very responsive and helpful. But in my communication with them on this matter, I feel that their lack of motivation comes from a false sense that their current solution works extremely well and no competitor is even close. I second to that. They are completely underestimating the problem. But on the other hand I consider the series 5 controller extremely overpriced. I have opened both boxes (EFA and Delta-T) and the content is less than 20$ worth. The profit margin is higher than with narcotics. An the development for that is also not worth the price. It is basic electronics out of the shelf.
Rouz Astro: In all fairness the DeltaT PWI3 combo has been working for me without the EFA despite freezing temps and very high RH.
CS Rouz While I do not dispute that, here is what their website says:  The content in the "Description" section is completely wrong, misleading, and would lead one to reasonably believe that the Delta T does stuff it does not do without the purchase of a second product the consumer would not otherwise purchase. You cannot monitor the current temperature of the primary mirror and surrounding ambient temperature with the purchase of the Delta T product alone. You must buy the EFA product, which costs MORE than the Delta T product does. This is bad business practice and is an anti-trust violation, read more here: Tying the Sale of Two Products | Federal Trade Commission (ftc.gov)It is not reasonable for a consumer to purchase an optional controller box for an optional focuser to get their optional Delta T unit to work as advertised here. No one should support what they are doing or make any excuses for them. They really, really need to fix this problem and provide impacted customers with a path to the results they promised the Delta T product would deliver on its own, which they have clearly called out here in this example.
It is not reasonable for a consumer to purchase an optional controller box for an optional focuser to get their optional Delta T unit to work as advertised here. No one should support what they are doing or make any excuses for them. They really, really need to fix this problem and provide impacted customers with a path to the results they promised the Delta T product would deliver on its own, which they have clearly called out here in this example. Bill, Unless they've changed the product significantly since I bought mine, you can indeed monitor the current temperature of the primary, secondary, and ambient temperature with just the Delta-T box. Without the EFA, the only thing missing is the ability to control the fans through the PW3 software. John PS. Here's an image of the data output from my system as it runs tonight showing all three temperatures. It also shows the status window of my controller. I had just turned on the heaters so the temperature of the primary and secondary were both climbing on the right. I believe that the RH reading in both sensors may be faulty so I often don't turn on the controller until the observatory monitors show the TDPS to be decreasing below ~5C. I have new replacement sensors ready to go to Chile with me when I do my service visit in late January.  |
John Hayes: Bill, Unless they've changed the product significantly since I bought mine, you can indeed monitor the current temperature of the primary, secondary, and ambient temperature with just the Delta-T box. Without the EFA, the only thing missing is the ability to control the fans through the PW3 software.
 Thanks John. The Primary mirror backplate data is supplied, but not the actual back of the mirror temp, which is in EFA. I guess I take half of what I was mad about back knowing this. They are not providing the exact data they claimed (primary mirror temp) but a rough approximation instead. I am curious to know if you have measured the difference in the backplate temp vs the primary mirror temp and found any linear relationship between the two? -Bill
I see it does say "Primary" in the description.
And you are right Bill, it does not provide the primary but the backplate. You will need the EFA for that. Pegasus said if they know the details they can make a wire to drive that focuser stepper motor with the UPB, no updates on that.
As for value, I can tell you the Pegasus UPB is about $650 and has about a page long list of features!
Rouz
