Dear Astrobin community,
I have recently bought an L-Ultimate dual band filter which I just tried using a Samysang 135 (at f/2) and an ASI071MC color camera. This gives a very wide field around 11deg by 7deg.
This is the first image, centered around the Crescent Nebula. 300s subframes, 13 of them taken between the clouds!
I like the contrast but I not so much the star halos, in particular around red stars!
I need your view on this particular issue of star halos. What do you think?
- This filter has an issue. I should send it back and ask for a new one
- This is a known issue, I should use an Antlia filter instead
- This is linked to the very fast system. Just live with it!
Thanks for your views!
Cheers and clear skies!
Hi Doversole83,
Great images! Unfortunately it seems that star halos are a common problem with Optolong filters. I have the L-eNhance and L-eXtreme, both of which produce halos around stars when I use either of them with my Radian 61.
I do agree with David's response about halos being caused by fast imaging systems, especially equipment that has f/2, which many duoband filters aren't good at emitting their full bandpasses due to band shift. There are definitely filters that are available and designed specifically for fast imaging systems, such as the IDAS NBZ or L-eXtreme f/2, although the L-eXtreme f/2 still produces halos, even Antlia's ALP-T f/2 filter produces halos whereas the normal ALP-T produces minimal to no halos from my observations. I found that out by watching Cuiv the Lazy Geek's and Lukomatico's reviews on it. In regards to the L-Ultimate, it can produce halos but from a few different reviews of the filter I have watched on YouTube, some people didn't experience halos whereas others did.
I wouldn't send the L-Ultimate back due to this. I would keep it as a backup in case you are in heavily light polluted skies and are imaging emission nebulae. If the halos are annoying you, I would try removing them in post-processing if you can. If you have the latest version of Photoshop, the new remove tool is amazing. I've used it with great success on my images plagued with halos. I've found the best results are achieved when the stars are taken out of the image, using something such as StarNet2 or StarXTerminator. I then carefully go around the area where the halo was and then see if anything else needs to be cleaned up, but most of the time I try not to do too much as I like maintaining the accuracy of what I shot.
If they are still annoying you, you could perhaps look at the Antlia ALP-T. It has 2nm less bandpass than the L-Ultimate, but it is very good for controlling star halos. I'm not trying to suggest that you go out and buy this filter, but it is another option if you feel that the halos are too much.
Ultimately, it's down to personal preference. I personally would like to try both the Antlia ALP-T and Optolong L-Ultimate one day, as both filters are very capable of producing excellent results. In fact, I loved my Optolong L-eNhance so much that I only just started using my L-eXtreme last week which had been sitting in my containers until then, and the difference between the two filters was mindblowing. The L-eXtreme has much more contrast than the L-eNhance!
Hope this helps.
Zak
