i got a question on people who own an octopi tilt adapter plate.
I got one and i dont know if i install right? Its need to be flat to the blue or the yellow arrow?
Can be remove the cover plate from the camera and setting up directly to the heating thin plate before sensor?
I am beginner in tilt and all this thing and would for any suggestition, pictures etc be happy.
Thak you all guys.
At the moment is leveled to the middle circle not to the outer which is a bit deeper. Maybe am i wrong?the pull and push crews are full screwed in and then when all things fixed i just tightened the push screws and wanna start my tilt adjustment process from here. If you crew a filter wheel on the camera you would do it in the inner plate and then i installed right or isnt?
Very Best Regards and thanks for any comment.
Attila
