Starnet leaving artifacts boxes behind Nikita Misiura StarNet · patrice_so · ... · 2 · 79 · 2
patrice_so 7.87
Hi there,
I cannot escape noticing that starnet2 is leaving square boxes in my images.
I noticed it before, but it is more visible now that I am processing mono data. Processingwise, I stack each L, R, G, B,  star align them and crop them. Then, to each layer, I apply Graxprt and BRX (first corr only, then normal run). I then combine R, G and B in linear mode, apply GMT and color calibrate with SPCC before finally removing the stars. At this point, there is no impact in starting by applying the L layer or by stretching everything first. The outcome is the same.
Any hint ?
Is StarX better in this respect ?
Patrice
Yes, SXT is better in that regards since it takes the scattering with the stars. It happens for overexposed stars more often than not.
MikeHuerto 2.39
Yes starx is better
