Square or circular? Moravian Instruments C3-61000 PRO · Riccardo Civati · ... · 9 · 326 · 0
AstroReghe 1.20
Hi all
Is true that Moravian C3-61000 Pro needs Square 50x50 filters because with circular filters there Is vignetting?
Riccardo
It depends on configuration, camera + optical system ahead of camera.
AstroReghe 1.20
TEC 140 ED with flattener 1x f/7.
Internal or external FW?
Either way, 50mm unmounted, round. You might get away with 2" mounted with the internal FW, by a very slim margin though. I wouldn't bank on it, however.
darkmattersastro 11.95
With your TEC140 you should be able to use 50mm round filters. If you were to upgrade to a different OTA in the future or to a larger sensor the square filters would be required. If you think that may be a possibility it could make sense to go to the 50mm square filters now.
carted2 4.17
Riccardo Civati:
Hi all
Riccardo
I'm using the C3-61000 camera on a 12.5" iDK at f/6.8 and I have the 50mm round filters. They work fine with no vignetting. Like Bill mentioned, if you plan on going with a bigger sensor in the future, the 50x50mm filters would make sense.
skybob727 6.67
I use 50x50mm on my C3-61000 because I already had them. If the price difference is not an issue, I'd just go with the 50x50mm.
AstroReghe 1.20
Daniel Carter:
Riccardo Civati:
Hi all
Riccardo
***Hi Daniel
can you send me your master flat frames stretchd ( all filters)?***
riccardo
carted2 4.17
Riccardo Civati:
Daniel Carter:
Riccardo Civati:
Hi all
Riccardo
***Hi Daniel
riccardo
I'll get them to you via private messaging later today or tomorrow morning.
