Gain in Moravian C3 Moravian Instruments C3-61000 PRO · Rafael Sampaio · ... · 18 · 384 · 1
rafaelss123 1.20
Hi everyone,
What gain you typically use with Moravian C3-61000 PRO ?
When using ZWO ASI6200mm , gain 100 turns on HCG high gain mode. So what is the equivalent gain on Moravian C3 to turn on HCG high gain mode?
CCDnOES 8.34
Moravian specs gain differently numerically. This is from the C3 product page...
darkmattersastro 11.95
Gain 0 for broadband and 2750 for NB.
carted2 4.17
I use the same Gain values for broadband and NB with my Moravian C3-26000 (ASP-C instead of full frame) and that has worked out well for me. I based those gain values off of the same information that Bill posted from Moravian's product page.
Wolfgang-Promper 6.85
2750 for everything
jrista 11.18
This is what I would do as well, unless you explicitly want very short LRGB exposures. If you want more reasonable LRGB exposures and frame counts, then I'd use gain 0 for that. You will get about half a stop more dynamic range, as well as a significantly larger well capacity, so you'll be able to expose for a good deal longer (probably a lot longer than necessary to swamp the read noise, which is a real bonus... That probably wouldn't quite be the case at 2750 for broadband.)
Jon Rista:
In my case, with the C5A-100M (same gain values) the subs are 300mb each. You don't want to live through stacking hundreds and hundreds of them. 🤯
skybob727 6.67
I'm glad all this came up as I just got a C3-61000 Pro and have a C3-26000 Pro on the way. Why would you not just leave it at 0 for both BB and NB
if exposure time is not an issue. I'll experiment, but plan to just stay at 0 gain.
Bob Lockwood:
The read noise is significantly lower at 2750 and there's no real drawback with NB.
rafaelss123 1.20
Using 0 gain means not only longer subs, but a much longer total exposure time needed, comparing when using 2750 (HCG)  gain. Right?
Or wrong?
Rafael Sampaio:
Or wrong?
No. You're still going to swamp the noise fairly quickly, you'll just have less saturated stars, which is why I use Gain 0. I want to prevent images with great extended objects but white washed out looking stars.
skybob727 6.67
To me, leaving it at 0 for broadband keeps the well depth as high as it can go, exposure time for me is not an issue, I typically do 10-15 minutes all the time.
For NB I guess going with 2750 will help with read noise and having the well depth drop to about 17k won't matter much with over saturation.
rogerg 1.20
2750 for everything with my C3 26000C
ashastry 2.81
Bob Lockwood:
Hi @Bill Long, given the ginormous 300MB sizes of the subs with the C5A-100M, I would be curious to hear if you have tried binning 2x2 (and in particular whatever Moravian calls “hardware” binning which course isn’t like CCD HW binning in terms of read noise) and running at gain 2750 for broadband?
I assume that the full-well capacity would be 4x higher, and so less likely to saturate stars even in broadband with gain 2750?
Wjdrijfhout 6.78
So far have only been using my C3-61000 Pro for a few weeks, all BD at gain 0. For NB I would default to 2750. The best settings will probably be different for different situations. It’s a balance between noise (or signal to noise) at the low end and saturation on the high end. I’ve found that my system (f/7.2) even at gain 0 does not easily saturate, so might even try 2750. For NB I would not see much benefit of gain 0 on my system.  But if you have a very fast system, this may be very different and a gain 0 for both NB and BD might work best?
Ani Shastry:
Bob Lockwood:
I haven't seen a way in their driver to use this mode. I'll have to double check and see if I can find it. If I can it's certainly worth a test.
Bill
Ani Shastry:
Bob Lockwood:
Bill
I think you need to set that in the .ini file
jhayes_tucson 26.84
Ani Shastry:
No, it doesn't quite work that way and that's the problem with binning in hardware with a CMOS camera.  They only transfer 16 bit values for each pixel so they typically-left shift the sum by 2 bytes to the left to produce an integer average of the value.  That strategy does give you more effective well depth at the expense of loosing 2 bytes of data resolution when you bin.  The only way to avoid that is to download the data binned 1x1 and then do a local 2x2 software bin in floating point.  The IntegerResample in PI will do this.  Of course this doesn't address the bandwidth problem.  Even if you downloaded a longer word for each pixel--say 32 bits, you end up with just as much data being transferred.  QHY claims to have an 18 bit download option but I believe that you have to write your own code to use that option.  It's not something that any current astro-software will deal with (at least that I know of.)
rafaelss123 1.20
John Hayes:
Ani Shastry:
Hi John! Thanks! And do you usually use gain for broadband?
