Hi, I am currently using the iGuider built into my CEM70. Cannot say I am super happy yet. Two things I have not solved: 1) In PhD2, on startup, the preview is at gain 0 and super bright. When I push it to full gain, I start seeing stars and the background is darker 2) When I do the above step, the image shows severe vertical banding These two things seem a bit "off" to me. I do get acceptable guding with this, in the 0.5" range. Still… Is someone else dealing with this; and is there perhaps a (permanent) solution? I did upgrade the firmware last spring; so it's at least not old "stock" firmware. Cheers, Marc |
Did you try redoing your dark library ?
Kash: Yes, a couple of times now |
I don't own an iGuider, but just in case: Does it have a native driver and an ASCOM driver. If so, have you tried both?
