Use of Siril in astro landscape Siril Team Siril · Raphael Lencrerot · ... · 13 · 501 · 2
raphael.lencrerot 0.00
I'm shooting astro landscape (not DSO). I was wondering if Siril could be beneficial to enhance my images in a certain manner. Originally I was thinking about looking at PI but the price is quite deterrent to get in.
I struggle to find tutorials that provide solid examples of the use of Siril in there workflow to enhance sky in astro landscape case.
Any suggestion?
Thanks in advance.
DavesView 2.39
Łukasz Żak is the best I've seen. Perhaps he can chime in for you.
NeilM 2.11
I agree!  Lukasz Zak has incredible landscape images!  However he doesn't list Siril as one of his tools so maybe he would be willing to share his process.
astro.darius 1.20
Raphael Lencrerot:
Yes, you can do the following:
- Shoot multiple exposures at the maximum shutter speed before seeing star trails. Usually it's the 500 rule: 500/focal ratio = number of seconds that you can shoot. However trial and error is best.
- Shoot some dark frames (same settings and shutter speed as the normal frames, but cover your lens with the lens cap and a blanket or something)
Then in SiriL:
- Import all dark frames and create your master dark: https://siril.org/tutorials/tuto-manual/#darks
- Start a new sequence and import the normal frames: https://siril.org/tutorials/tuto-manual/#converting-files
- Import all frames, convert them to FIT, then use the Calibration menu to calibrate them with your master dark.
- Register and Stack all the photos using SiriL and ignore the fact that the landscape will be completely black.
- Crop the image so only the sky is visible
- Go to Image Processing -> Background Extraction and use RBF to extract the background sky. This is done by clicking Generate, then making sure that none of the squares are on stars or on very light areas, then clicking on "Compute Background" and "Apply". To remove squares, use right click. To add squares, use left click.
- If needed, go to Image Processing -> Generalized Hyperbolic Stretch Transformations and stretch the histogram according to your taste.
- Alternatively, instead of GHST you can use Image Processing -> Histogram Transformation. This option is much easier to use and more in-line with traditional photo editing software, but it doesn't give you as much control as GHST.
- Save as TIFF
- In your favourite raw processor (I use CaptureOne), edit one of the photos - not the tiff, but one of the raw photos from your camera - until your are satisfied with how the foreground looks. Export this as TIFF.
- In your favourite photo editor (I use Affinity Photo), load both TIFF files as layers, align them and then combine them to your liking so that the final image will be composed of the single-shot foreground and the stacked sky.
Export this as TIFF
- Load the final TIFF into your raw processor - CaptureOne in my case - and do any final post-processing edits to the composite image.
Export, publish and have fun!
Example: https://www.astrobin.com/u175sw/  (no darks, just light frames)
Clear skies!
NeilM 2.11
That's an amazing Photograph, Darius!
ejsengineer 2.39
My lastest image in my gallery is a landscape edited in Siril: https://www.astrobin.com/h87ur3/
I find that Siril doesn't do a good job stacking with very short focal lengths (my case was a 14mm Rokinon). So I stacked in Sequator.
I cropped out the foreground on each image prior to stacking, I got better results than keeping the foreground in. Just be sure that your crop size is identical across all images.
Once stacked I went into Siril for PCC, SCNR and starnet. No background extraction (it looks too flat for landscapes)
Starless image stretching was done in Siril (arcsin, Histogram, and GHS)
Then saved the starlesss as a TIF to be brought over to Photoshop for final touches.
I then opened the TIF in Siril saved as a FIT and did star recomposition with the star mask (I like Star recomposition better than just doing a screen blend in Photoshop)
Saved the combined image as a TIF and brought back into photoshop to replace the sky on my foreground image.
Alot of back and forth but I thought it worked out better than just editing in Photoshop.
It's by no means a professional image but I'm happy with it!
CS!
astro.darius 1.20
Thank you
astro.darius 1.20
Ethan Sweet:
CS!
Interesting idea with extracting the stars prior to stretching on landscapes, it definitely allows to have a bit dimmer stars in the final composition. Nice.
mmbejerano 0.00
Raphael Lencrerot:
Any suggestion?
Thanks in advance.
https://sites.google.com/view/sequator/introduction
mmbejerano 0.00
Prueba este programa gratuito
Ecliptico 2.41
For what I have read so far, the answer seems to be a Go for Siril. That said, you might want to consider looking if Sequator might be another good free of charge alternative for you (https://sites.google.com/view/sequator/download). That software seems to be a good performer on landscape imaging.
Thanks for your reply. I wasn't clear in my first post sorry for that.
I'm not really looking for a stacking tool. When doing astro landscape with a tracker, sometime you can afford to do stack sometime not, especially if you do MW arch for instance. I was wondering if I could enhance the image (post-processing part) with a tool such as Siril in astro landscape case. I'll put image example I did recently, processed with Lightroom and photoshop. I just wanted to know if I could do better with a tool such as Siril or PI. But PI cost is deterrent.
Mbx 0.00
magnifiques photos (je me permet le Fr a la vue du nom)
je pensais te parler d'autostacker mais c est plus pour du planetaire effectivement, je pense qu'a grand coup de tutos tu dois pouvoir améliorer (légérement) tes photos avec Siril mais elles sont deja superbes…
magnificent photos
I thought to speak to you about autostacker but it is more for planetary indeed, I think that with some  tutorials you should be able to improve (slightly) your photos with Siril but they are already superb…
Jefwizz 0.00
Bonjour Raphael,
Pour le post-traitement j'utilise Affinity Photo (puissant outil sans abonnement à un prix ultra concurrentiel), les outils de RC-Astro (notamment NoiseXTerminator) et les fabuleuses macros de James Ritson (JR-Astrophotography pour Affinity Photo). Ces macros étant gratuites, seule une participation facultative (mais largement méritée)  est demandée.
_____________________________
Hi Raphael,
For post-processing I use Affinity Photo (a powerful, subscription-free tool at a very competitive price), RC-Astro's tools (especially NoiseXTerminator) and James Ritson's fabulous macros (JR-Astrophotography for Affinity Photo). As these macros are free, only an optional (but well earned) subscription fee is required.
